I have a HALL SCOTT "RUCKSTELL" 2 speed rear end in my Model TT truck. It has both of the names on it, as an example of the naming, just like the shifting level that is in the first two pictures. But what I found interesting is the early shift lock body (in the 3rd and 4th pictures) is made of brass. So my question is; Has anyone seen a shift lock like that one before? I am thinking of removing the black paint to show it off. It also has an adjustable screw with a nut on it to keep the shift lock lever snug for a smooth action.
SHIFTING LEVER
BRASS SHIFT LOCK
HALL SCOTT "Ruckstell" early BRASS SHIFT LOCK BODY
Topic author - Posts: 499
- First Name: Steven
- Last Name: Sebaugh
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
1924 Model TT Truck
- First Name: Rod
- Last Name: Petrie
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
Re: HALL SCOTT "Ruckstell" early BRASS SHIFT LOCK BODY
I have a spare brass one but am using a cast iron one,
- Last Name: Blaydon
That shifter lever is interesting. Wish they would have stuck with that design!
I prefer the brass housing. It makes it far easier to ream a worn hole to take a thin wall bronze bushing to rebuild the thing.
The shifter handle is TT for sure - have seen many Hall-Scott brass car shifter bodies but not too many TT ones.
- Last Name: Stroud
- Board Member Since: 2011
That TT shift lever is very similar to one for a TT Rocky Mountain Six Speed shifter. Interesting. Dave
1925 mostly original coupe.
