Found this not so old pic...
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Sep 23, 2020 7:19 pm
Was rummaging thru some boxes today and found this...
And NO! It’s not photoshopped!😉
AdminJeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Re: Found this not so old pic...
Post by AdminJeff » Fri Sep 25, 2020 1:33 am
Ok, I'll bite. Where/what is it?
AdminJeff
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
halftracknut
First Name: randy
Last Name: lee
* REQUIRED* Type and Year of Model Ts owned: 1926 pickup
Post by halftracknut » Fri Sep 25, 2020 1:54 am
looks like the spruce goose...
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Fri Sep 25, 2020 6:46 am
Looks to small for the goose. What museum?
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Jonahdavella@gmail.com
Last Name: Wrenn
Post by TWrenn » Fri Sep 25, 2020 8:00 am
Definitely the Spruce Goose. Here's a pic I found on the good ol' Internet!
Check out the building. They must have just changed things around it a bit.
Have no idea where it is. The pic didn't say. Or at least I didn't see it!
John Warren
Last Name: Warren
Post by John Warren » Fri Sep 25, 2020 8:14 am
Spruce Goose, Now in McMinnville Oregon
spruce goose.png (69.96 KiB) Viewed 6064 times
John Warren
Last Name: Warren
Post by John Warren » Fri Sep 25, 2020 8:16 am
Thats is a big WOW. Kevin is that your car? Thanks for sharing.
John Warren
Last Name: Warren
Post by John Warren » Fri Sep 25, 2020 8:50 am
I would love to go and see her in her new home. I did see her in Long Beach, and yes I must be getting older. May be a Tour or speedster run??
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 25, 2020 9:51 am
Was a NWVS Labor Day endurance run... bout a dozen or so years ago. The Evergreen museum had relatively just recently opened and they were letting us pull out cars in to snap a shot under the ‘ol goose (Hercules). Have been back a couple times since, and it has changed a bunch every time. I highly recommend checkin it out if you’re ever near Portland
John Warren
Last Name: Warren
Post by John Warren » Fri Sep 25, 2020 10:22 am
How about some more photos of your car? Thanks.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 25, 2020 10:54 am
She’s been shined up a bit since! Looks like these are bout all I’ve got...
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Fri Sep 25, 2020 11:06 am
Very nice Kevin. Good proportions.
How about the engine pictures?
( Nothing like red wheels). :D
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 25, 2020 11:17 am
All flat heads look the same...🙄
So how bout what’s on the way...?😁
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Fri Sep 25, 2020 11:23 am
That should make it go.
Better have good brakes to match. :lol:
Post by Steve Jelf » Fri Sep 25, 2020 11:47 am
I was almost five when I saw part of the plane. It was being transported in sections from the Hughes plant near Playa del Rey to Long Beach for assembly in the harbor. The driver of the truck hauling one of the wings parked by our house on PCH while he went into the cafe next door for a cup of coffee, so the wing was about twenty feet from my bedroom. A crowd of neighbors gathered to check it out and my friend Scott Shell, who was a year older, informed me that it was part of the biggest plane in the world.
Post by Mark Gregush » Fri Sep 25, 2020 12:29 pm
It's in McMinnville Or. and about 37 miles from Portland.
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Fri Sep 25, 2020 1:01 pm
With all the aeronautical engineering that went in to the Spruce Goose the engines were not mounted correctly and that caused extreme vibration and it had to be put back in to the water, otherwise it probably would have flown ok. When you look at the wing angle and the angle of attack of each engine they are all off by a few degrees just enough to cause each propeller to cut the air at an angle not relative to the direction of the airplane. I have flown small airplanes when when the angle of attack is not consistent with the direction of flow and the airplane will vibrate violently for a few seconds until it straightens out then all is ok, but the Goose there was no getting out of it leaving the only option, to abort.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Fri Sep 25, 2020 1:30 pm
A friend is about to give me the running gear and both axles (no frame) out of his 31 Model A pickup.
This is kind of what I had in mind.
1924 Touring
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Fri Sep 25, 2020 1:54 pm
Now I see his juice brakes. Well done. Hard to spot.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 25, 2020 11:12 pm
They are motorcycle disk on all 4 corners. Someday I hope to build an era correct set of drums to replace em tho. They work great... but stick out like a sore thumb on an otherwise relatively period correct car
Here’s a sneak peak at the design inspiration, ‘36 Bentley...
Currently the plan would be to hydraulically actuate/equalize rod or cable linkage so all modern equipment is hidden under the car. All I have to do now is finish my Akron-Hed project and about fifty others before I can start...
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Fri Sep 25, 2020 11:19 pm
The Spruce Goose was a good idea, poorly executed. With the German U-boats taking a heavy toll on Atlantic shipping, the US needed a better way to transport troops and supplies across the ocean. If the plane had been finished sooner and made of aluminum, its history may have been different.
ShirkWood
First Name: Verne
Last Name: Shirk
Post by ShirkWood » Tue Sep 29, 2020 4:48 pm
Orie Jones, the woodworking teacher back when I went to North High School, in Wichita, Kansas, (1970) had worked for Howard Hughes. Orie helped build the Spruce Goose. He even had some of the scrap wood from the plane which he used to built tools for around the shop. I went in before and after school and built the body for my 1914 T Hucksters Wagon while in high school there. Orie was a neat old guy and gave me some really good pointers on building the body.
Verne Shirk
Wichita, KS
Eagle Pix of top.jpg (58.61 KiB) Viewed 5617 times
John Warren
Last Name: Warren
Post by John Warren » Tue Sep 29, 2020 5:33 pm
Kevin , nice car!! thanks. David, first I have heard of the engines mounted incorrectly seems like Hughes got it from all sides. When they were talking about moving it,possibly to Lake Mead to use as a gambling boat, the news caster commented how unstable the H4 was????? Im sure he was correct watching how much Howard was fighting to keep it from rolling over HaHaHa. . Views from the cockpit doesn't indicate any vibration. Verne nice story and body. Steve thanks for your story. I am also wanting to put better brakes on my race car. I am hoping to hide discs inside drums. I installed Cleveland brakes off a small airplane on my sandrail. They worked well and were simple to install.
John Warren
Last Name: Warren
Post by John Warren » Tue Sep 29, 2020 5:46 pm
The old Sandrail has seen better days. The brakes are small but effective.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Sep 30, 2020 11:57 pm
Must get good traction with the tire pressure that low...😜
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Thu Oct 01, 2020 9:16 am
I just adjusted the brakes on my friends '49 Bentley. Let me know if you need more pictures.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Thu Oct 01, 2020 11:45 am
" All I have to do now is finish my Akron-Hed project and about fifty others before I can start...". Ha Ha! You have two projects that come to mind that you will NEVER be done with! Been there- doin' it.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Oct 02, 2020 2:04 pm
I hear ya Dan! Waaaaay underestimated the time on this job!😜
Dan McEachern
First Name: DAN
Post by Dan McEachern » Fri Oct 02, 2020 3:13 pm
Wait till they think your speedster is theirs!
