16 Touring top pad replacement
mark30h
First Name: Joe
Last Name: Salemi
* REQUIRED* Type and Year of Model Ts owned: 1916 touring
Board Member Since: 2014
Post by mark30h » Wed Sep 23, 2020 3:45 pm
Is it possible to replace top pads without fully removing the top? We put the top on my 16 50 years ago, and the covering is still in excellent shape, except for some minor discoloration of the rear window. Its always been stored up, except for stupidly leaving it down last winter, when a rodent helped itself to one of the pads. My dad and installed the top when we restored the car, and for sentimental reasons,I'm wondering if its possible to brace the bows, remove the tacks partially on one side enough to expose the pad, and replace it.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Re: 16 Touring top pad replacement
Post by R.V.Anderson » Wed Sep 23, 2020 6:24 pm
You probably could, or if you're nervous about doing it, a local upholsterer could tackle it.
mark30h
First Name: Joe
Last Name: Salemi
Post by mark30h » Fri Sep 25, 2020 7:18 pm
I think I'm going to replace just the pad. I know that when we did the top , no glues were used , so if I get a pad kit, and some new tacks for the covering, I should be ok.
TheSaintDiscJockey
First Name: Brooks
Last Name: Schlieben
* REQUIRED* Type and Year of Model Ts owned: 1923 TT
Post by TheSaintDiscJockey » Fri Sep 25, 2020 7:40 pm
:evil: I don't see a problem. I would do one side at a time. Looks like that top was expertly done all those years ago.
