I have a generator that pegs the amp meter while running fast idle and after a few minutes run time the commutator starts to get hot and smoke. Took the brush cover off and while running there are sparks running around the commutator from the brushes. Wiring is correct and when a load is put on ,the amp meter discharges while not running.
Any ideas?
Generator trouble shooting. Suggestions?
Topic author - Posts: 254
- First Name: Dennis
- Last Name: Fleming
- * REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
- Last Name: Hunter
- Board Member Since: 2002
Re: Generator trouble shooting. Suggestions?
The charge current would appear to be excessive. Try changing the position of the 3rd brush to reduce it down to about 5A. If that doesn't work, the next thing I'd do is check the position of the brush plate. That entails removing the generator from the engine and connecting it to a battery so it runs as a motor. The third brush is lifted off the commutator and the brush plate is rotated to its null point; i.e. the generator stops spinning in one direction or the other. Then it can be put back in the car and the third brush set in the usual way. Be aware that many original brush plates crumble apart if the nut securing the 3rd brush has been tightened excessively. When that happens, the 3rd brush becomes grounded and it won't charge.There's a good fibreglass repro if it needs replacement.
- First Name: Philip
- Last Name: Thompson
Read the generator section in the Ford manual it tells you how to set the neutral
And then the output of you don't fix it it will be toast.
Dennis
Give me a call and I will try to help.
Ron Patterson
Ron Patterson
