13T - Requesting 1909-1914 wire harness/engine compartment pic
Topic author - Posts: 256
- First Name: Darin
- Last Name: Hull
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
- Board Member Since: 2010
Does anyone have a picture of their wiring harness in the engine compartment if you have it setup pretty close to original? I saw this part from Langs says it's the original style harness for a 1909-1914.
Also, curious how it is hooked up/oriented in the engine compartment. I have a wiring harness which doesn't look like this one and I know I have it routed incorrectly... as I take it around the water outlet side of the block. Curious if anyone else has this original style and how you route it so as not to risk burning it on the exhaust manifold.
Thank you for your time,
Darin
Darin
Re: 13T - Requesting 1909-1914 wire harness/engine compartment pic
This sketch and old photo should help.
Metal clips under the hood shelf hold the loom to the frame rail.
There is a small brass clip held on with two small brass round head nails near the #1 spark plug terminal probably about 4" away. Maybe someone has a photo?
- First Name: Darin
- Last Name: Hull
Dan, that pic you posted showing the harness going up the firewall is what I was looking for. That makes sense to keep the harness away from the exhaust manifold. I’ll need to find a clip and that magic can happen.
I’ll keep looking for some good pics of restored 09-14 engine compartments but think that explains it.
Thank you,
Darin
Thank you,
Darin
Darin
That clip is up under the hood former so it cannot be seen in photos. According to John Regan, the clip is brass, then later steel, but held with brass roundheaded tacks, and is about 4" or so away and a bit up from the # 1 coil terminal. Lang's make them I believe.
- First Name: Darin
- Last Name: Hull
Dan,
Great help, thank you!
Darin
Darin
- First Name: Tony
- Last Name: Bowker
While I was working on my 09 I took a photo of Kim Dobbins very original 1910.
I duplicated it on my 09 except I never found the correct clip. Hopefully the new owner will find one or make an appropriate clip.
Tony Bowker
La Mesa, California
La Mesa, California
- First Name: Darin
- Last Name: Hull
Tony,
Another excellent reference pic. Thank you for your time sharing that pic.
Darin
Darin
