need a sorcerer
Topic author - Posts: 517
- First Name: Andre
- Last Name: Valkenaers
need a sorcerer
It is almost halloween
I am looking for a sorcerer or maybe a beautyfull sorceress will be better to learn to do some sorcery.
Just get these coils to be repaired.
Some suggestions??
Andre
Belgium
Some suggestions??
Andre
Belgium
Re: need a sorcerer
Most of the coils you have pictured are not worth the effort to repair. Here in the U.S. they are easy to find. Since you are in Europe, I suggest ebay.
You probably don't have cores that are rebuildable. You can buy coils from Fun Projects, or other dealers such as Langs.
Re: need a sorcerer
There is a fellow near you who does fantastic work with coils. I'll try to find his name.
RichWhen did I do that?
Re: need a sorcerer
I believe I detect a bit of trans-Atlantic leg-pulling going on here.
Re: need a sorcerer
Trust the FORCE Andre
- First Name: William
- Last Name: May
Re: need a sorcerer
Yoda - messing with the coil boxes while the engine is running, learns a valuable lesson, he does!
Don't mess with the "Power of the Fords!"
- Last Name: May
Re: need a sorcerer
I think he can get 4 good operating coil boxes out of his assortment. He will have to replace some parts, I'm sure. But he will have to work on them quite a bit.
He might want to see if he can trade them in as cores on some rebuilt and adjusted units. That would be the easiest route. I know a LOT of coil rebuilders have been running short of cores to rebuild recently. That is what I would try first.
- First Name: Mario
- Last Name: Brossard
Re: need a sorcerer
Seriously Ron is a master with coils. I have 8 coils and one coil box from him and they worked like heaven!
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Andre
Re: need a sorcerer
Just get a mail from Lang.
The capacitors are available again ordered 12 sets.
Some part of the sorcery is done. Now I need to find some elbow grease. Were can I find this?? Yoda maybe??
André
André
Re: need a sorcerer
There's one on eBay seller's location Alderaan?
- Attachments
- gre.jpg (30.4 KiB) Viewed 2751 times
- First Name: Anthonie
- Last Name: Boer
Re: need a sorcerer
Andre', I know what you mean !!!!
Toon
Toon
Re: need a sorcerer
Explains the new capacitor difference from the previous ones. New is better. The manufacturers part number and spec is displayed
http://www.mtfca.com/discus/messages/17 ... 1322781074
- First Name: Andre
Re: need a sorcerer
Today I get the visit of a GOOD Witch.
Here is what we did together. Made 6 out of 8
The metal top coil need only a refill
The others need the points and are waiting for the new capacitors I ordered last week.
Andre
Belgium
Andre
Belgium
