Removal of old silicone used used a gasket
Topic author - Posts: 254
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
When you separate parts that have silicone used as a gasket there is always a film left.Spray the surface with brake clean and it will loosen up and you can scrape it off. I am not a purist but really helps seal things, especially in an emergency but we all know Model T,s never brake down on the road away from home.
