Battery carrier tool...old school
Topic author - Posts: 485
- First Name: Jack
- Last Name: Putnam
Interesting design on this battery tool. Perhaps not a well thought out design, but well built. What are your thoughts? Probably was not a big seller.
Last edited by Jack Putnam, in Ohio on Sun Nov 15, 2020 9:22 pm, edited 1 time in total.
- First Name: Jeffrey
- Last Name: Hausey
Re: Battery carrier tool...old school
Being a retired electrician, I can tell you that is an accident looking for a place to happen.
Ever see a wet cell battery explode? Not pretty.
Shocking to me
- Last Name: Hausey
This is what you want. Same idea, but safer. Mine gave up after 45 years. This one is two years old.
quote " Mine gave up after 45 years. This one is two years old."
Mine must have had less use, still going strong after 54 years
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
I wonder if this tool was a link used to connect two batteries for series battery charging?
I have seen pictures where a number of batteries were hooked in series for charging at charging stations.
Few people had their own battery chargers. We never even had electricity at our house until 1967.
If our battery was dead on the 41 Dodge truck we would wait until someone came to visit.
We would take their battery out, start our truck then put our battery in the 41 to charge it up.
Harry
Harry
- First Name: Dennis
- Last Name: Hoshield
- * REQUIRED* Type and Year of Model Ts owned: '24 RPU (Raodster converted to Pickup)
Jack.... Not a good idea if both ends are connected.... But you can carry and sling a battery around by just one terminal. Another 'not a good idea', though! Lol!
BigBird... I have one just like that.... Only probably 45 years +, as well.
'24 RPU
Petoskey, Mi
Petoskey, Mi
I have seen a car battery explode! It was about like a cherry bomb, if not nearly an M-80! I was never dumb enough to play with those things, but some cousins of mine played with them a lot! It sure made a mess in my pickup. I had to hose out the engine compartment, clean it out, repair some damage. All that before I could scrape up a battery to get me home that night.
Hard to believe someone actually thought a steel to steel handle between the terminal posts would be a good idea. Perhaps they began with some sort of insulator between the handles and the post hooks? Still, talk about an accident waiting to happen.
Harry L's suggestion would be better? But also be unreliable due to poor connections.
Really makes one wonder.
- First Name: Henry
- Last Name: Lee
A first for me Jack! Thanks for sharing!
Hank
Hank
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
I’m with Harry. No way that’s a carrier. Even as a jumper it’s a damn poor design as some poor schnook would use it as a carrier sooner or later.
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Dan, I have one like that as well. I didn't keep the sales receipt but I know it's at least from the 1960's. Great design and well made. I misplaced it for a while and bought a newer version that isn't nearly as good.
Someway somehow that tool has to be used for another purpose besides carrying a battery. Just doesn’t seem practical for ‘carrying’ a battery. Maybe carrying a dead battery but even then not so much.
It would interesting to see if the other end of the tool has the - minus mark on it.
- Last Name: Hausey
It looks like the positive end at one time had an insulated bushing on the swivel pin or coating. Hard to say.Jack Putnam, in Ohio wrote: ↑Sun Nov 15, 2020 8:52 pmInteresting design on this battery tool. Perhaps not a well thought out design, but well built. What are your thoughts? Probably was not a big seller.
- First Name: Jim
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
Does someone still sell these?
- Last Name: Morsher
Growing up in northern Ohio, we would call that a certain ethnic battery carrier. Anyone remember BIG CHUCK and HOOLIHAN ?
- Last Name: Seth
Those rings on the pliers were added so you could hang them from your ears while using the screwdriver for a chisel or paint stir stick. That way you didn't lose them.
