How to install modern needle replacement in NH Carb
Topic author - Posts: 1202
- First Name: Mario
- Last Name: Brossard
Hi, I would like to install a Modern style replacement for needle and seat on my Holley NH. I never make it before. Anyone could share me the procedure as well?
- Attachments
- NH replacement.GIF (8.58 KiB) Viewed 1814 times
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
Re: How to install modern needle replacement in NH Carb
I would not do it. Those things have a bad reputation. I would use an original float valve or a new one from Scott Conger.
- Last Name: Hatch
Get one of Scott’s tools for removing and installing the valve too!
- Last Name: Seress
I would highly recommend you talk to Russ Potter for guidance. He is installing two of those float valves on my two holly G carburators. As he advertises he is the King/prime authority on model T carburators. He has done great job on carburators for me in the past. Frank
- First Name: Mario
Thank you all. I have the tool from Scott. Working really well. My NH come from Russ Potter as well. A friend of mine recommended to me the modern one because it avoid to be stuck as the regular needle. But I thought I will keep as is finally with the needle Russ use.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
