Alchohol?
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Alchohol?
Post by Jonah D'Avella » Mon Nov 16, 2020 12:06 pm
Occasionally, it becomes freezing temperature where I live. Recently I've been using antifreeze in my radiator but it has been leaking badly and I am concerned about my pets attempting to consume the drips. Would a 50/50 mix of denatured alcohol and water substitute for antifreeze?
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Jonahdavella@gmail.com
Re: Alchohol?
Post by DanTreace » Mon Nov 16, 2020 12:16 pm
Alcohol works, but evaporates fast so freeze protection is limited.
And your pets could get drunk or injured as denatured alcohol is poison from those leaks too :(
Better to keep pets away from the storage garage, oil, gas, other things are harmful too.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Re: Alchohol?
Post by Jonah D'Avella » Mon Nov 16, 2020 12:29 pm
I am looking for a better solution than antifreeze. Antifreeze is sweet and appealing to dogs and cats and alcohol is less apealing.
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Peter, Memphis TN
First Name: Peter
Last Name: Claverie
Re: Alchohol?
Post by Peter, Memphis TN » Mon Nov 16, 2020 12:43 pm
The only sure thing I can think of, is to drain the cooling system when not driving the car.
Or, you could try to seal the system. There are plenty of radiator sealing products available at any auto parts store.
Last Name: Seth
Re: Alchohol?
Post by perry kete » Mon Nov 16, 2020 12:48 pm
Or tell your pets to stay away from your car or else!
Re: Alchohol?
Post by DanTreace » Mon Nov 16, 2020 1:02 pm
Since we don't have pets......never knew this product was out there :o
RustyFords
First Name: Don
Last Name: Allen
Re: Alchohol?
Post by RustyFords » Mon Nov 16, 2020 1:25 pm
Denatured alcohol is typical denatured with methanol....so it'd be pretty nasty for a pet as well.
Maybe not as quickly harmful...but not good at all.
You're correct about the sweet part though. They may not find it to be as appealing.
My solution has always been to make sure my cooling system has absolutely no leaks. In the instances where I have had a car that has a leak that I haven't had a chance to fix, the car is absolutely locked away from pets until it gets fixed. And even then, there is a towel or something placed under the leak to absorb it in the meantime. When disposing of ethylene glycol, if any has leaked on the driveway, etc it gets cleaned up immediately.
1924 Touring
Last Name: Hatch
Re: Alchohol?
Post by Dan Hatch » Mon Nov 16, 2020 1:31 pm
Why not fix the leaks?
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Re: Alchohol?
Post by Steve Hughes » Mon Nov 16, 2020 1:46 pm
I was not familiar with the product that Dan Treace posted but I have been using Sierra antifreeze. It is a propylene glycol based antifreeze and is safe for pets. That is probably what the other product is as well.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Re: Alchohol?
Post by Jonah D'Avella » Mon Nov 16, 2020 1:49 pm
My t is in a large barn. The doors are not tight enough to keep out animals. I can't afford to have my radiator fixed by a pro. I am currently putting a bucket under it. Any other suggestions?
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Alchohol?
Post by Rich Bingham » Mon Nov 16, 2020 2:02 pm
I'm in your situation too, Jonah. My Lizzie seeps enough that antifreeze (harder to contain than water, BTW) isnt a good option for me. Drain and re-fill is cumbersome but my best option. 3 gallons isn't that much to handle easily and there's a plus - if you can refill with hot water, your T will start easier ! :lol:
"Get a horse !"
Last Name: Hatch
Re: Alchohol?
Post by Dan Hatch » Mon Nov 16, 2020 2:36 pm
There is a whole chapter in Ford service manual on fixing a radiator. Starts of Par 788 I think. This was written for someone who did not know how to fix a radiator.
If you want one to practice on, you can have a junk one of mine. Pickup only no shipping. Dan
Last Name: Wrenn
Re: Alchohol?
Post by TWrenn » Mon Nov 16, 2020 2:52 pm
Jonah, (and Steve), I have used the LowTox antifreeze in the past, trouble is, it's pretty darned expensive, so if it's just
gonna leak out, take the other guys advice and when it's gonna get cold and you're just using good ol plain water, take the 5 minutes and just drain it. Then, when you get time and money, maybe send the radiator in to a shop to get it fixed. I bet for less than $300 you can get it taken care of. Maybe even a re-core, which will cost a bit more, but certainly a lot less than the average $900 for a black radiator. I spent $140 a month ago and had my Fordor's rad repaired and boiled out and wow it works now like it was brand new, not bad for an original round tube radiator!
BTW...at the risk of ticking off suggestions for "stop leak" stuff...DON'T. You'll hear plenty of horror stories as to how it surely stopped the leaks, but also stopped the COOLING along with it! It tends to plug up more than just the leaks. Do it right, fix or replace! You know the acronym... F-O-x-x! I won't fill in all the letters! Ha ha.
Re: Alchohol?
Post by TRDxB2 » Mon Nov 16, 2020 3:14 pm
The first "antifreeze" was Glycerol (glycerine is the commercial 95% form of glycerol used in hand sanitizers etc) was replaced with a cheaper solution Ethylene Glycol about the late '20s https://en.wikipedia.org/wiki/Glycerol
In the food industry it is called propylene glycol and used as an antifreeze because of its low toxicity. There are several products available for automotive use like the one described above, Prestone's LowTox.
Explanation of the difference between propylene glycol and ethylene glycol
https://www.monarchchemicals.co.uk/Info ... antifreeze
NOTE: Besides the issue with evaporation, Denatured Alcohol is poisonous: denatured alcohol is sometimes consumed as a surrogate alcohol. This can result in blindness or death if it contains methanol. https://en.wikipedia.org/wiki/Denatured_alcohol
Re: Alchohol?
Post by Jerry VanOoteghem » Mon Nov 16, 2020 3:55 pm
Drain it.
It's what people did in the Model T era. Enjoy the true Model T experience. :)
Re: Alchohol?
Post by Norman Kling » Mon Nov 16, 2020 4:29 pm
I have no idea where Kingsport is, so don't know how cold it gets there. But you need a good radiator to hold the coolant for long periods. If it only gets below freezing occasionally you can just use water in the cooling system. and drain only when the weather report says it will be below freezing. If you have hard water, use distilled water. That also costs you more than tap water but less than anti-freeze. If it gets below freezing for months at a time, drain and only fill if you are planning to start the engine. Over a period of time, you might be able to save enough money to buy a new radiator, or take the existing radiator to a shop to see if it can be repaired or re-cored.
Last Name: Wrenn
Re: Alchohol?
Post by TWrenn » Tue Nov 17, 2020 9:19 am
He's in Tennessee...so he will get a few days where it could freeze. Eventually he'll either get it repaired/re-cored, or best to replace it. Like most of us!! :lol:
Loftfield
First Name: Thomas
Last Name: Loftfield
* REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1912 Express Pick-up
Re: Alchohol?
Post by Loftfield » Tue Nov 17, 2020 10:18 am
Look. You live in Tennessee. I live in North Carolina. I know that you, like me, have access to seriously good moonshine at a good price. Forget the denatured alcohol that is poison. Get your moonshine, use that, and nobody gets sick. The only sadness is putting the moonshine into the Model T instead of into yourself. OK, maybe you split the shine in half, one part for the T, one part for you. Win-win!
Re: Alchohol?
Post by Steve Jelf » Tue Nov 17, 2020 11:17 am
Put chicken wire over the bucket so the critters can't get in it. Wire it to a piece of plywood so they can't tip it over.
ModelT46
First Name: Darel
Last Name: Leipold
Re: Alchohol?
Post by ModelT46 » Tue Nov 17, 2020 12:43 pm
The radiator in my Ten is tight, but will drip a bit, so I use the "safe for pets tpye' Alchohol I reserve for my personal use.
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Alchohol?
Post by Erik Johnson » Tue Nov 17, 2020 1:13 pm
A late neighbor told me that he was still using methanol anti-freeze into the late 1950s because it was less expensive than ethylene glycol anti-freeze.
However, while driving with his young daughters in the car, he experienced an engine fire which he attributed to a cooling system leak. After that episode, he switched to Prestone.
He and his brother were engineers and very mechanically inclined, hands-on car guys who did most of their own maintenance and repairs.
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Alchohol?
Post by Erik Johnson » Tue Nov 17, 2020 5:36 pm
Just had a conversation with my dad.
He said in winter months he used alcohol anti-freeze in his 1927 Fordor that he owned in 1948-49.
Also worth mentioning: I did some casual Googling of photos of vintage methanol anti-freeze cans and it seems that some manufacturers included water pump lube (soluble oil) with the alcohol. If you did use denatured alcohol and water in your cooling system, it might be a good idea to throw in some water pump lube.
Charles J
First Name: Charles
Last Name: Jenkins
* REQUIRED* Type and Year of Model Ts owned: Coupe
Re: Alchohol?
Post by Charles J » Tue Nov 17, 2020 6:46 pm
Had a small leak in mind I use two tablespoons of ground ginger and a cup of hot water it has not leaked the drop read this in a no repair manual it works
Tmooreheadf
Last Name: Moorehead
Re: Alchohol?
Post by Tmooreheadf » Tue Nov 17, 2020 9:32 pm
If regular antifreeze is sweet smelling to critters,I wonder what would happen if a bottle of Tabasco sauce were poured in, if the taste would change as to not be desirable to said critters? I wouldn’t think it would hurt anything in the cooling system.
big2bird
First Name: Jeffrey
Last Name: Hausey
Re: Alchohol?
Post by big2bird » Tue Nov 17, 2020 9:37 pm
I use vodka. IF the car breaks down....... :lol:
Last Name: Patrick
Re: Alchohol?
Post by jiminbartow » Tue Nov 17, 2020 10:55 pm
I just read an article about taste deterrents to prevent pets from eating things they ought not. It involves using solutions that repel dogs and cats through repulsive smells and tastes. Here is the article that includes some products that are marketed for this purpose. I’m thinking they can be mixed in with the radiator solution: https://pets.webmd.com/taste-deterrents#1. Jim Patrick
Last Name: Hjortnaes
Re: Alchohol?
Post by DHort » Wed Nov 18, 2020 12:29 am
You forget that Jonah is too young to have anything to do with alcohol or moonshine.
big2bird
First Name: Jeffrey
Last Name: Hausey
Re: Alchohol?
Post by big2bird » Wed Nov 18, 2020 2:07 pm
I am quite sure he knows what a joke is.
If not, I apologize.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Re: Alchohol?
Post by Jonah D'Avella » Thu Nov 19, 2020 6:17 am
Joke? I don got me 3 gallons yesterda! :D
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
GrandpaFord
First Name: Neil
Last Name: Kaminar
Re: Alchohol?
Post by GrandpaFord » Thu Nov 19, 2020 7:53 am
The RV dealers sell a non-toxic antifreeze that is used to winterize RV's. Boats use this too. See https://www.campingworld.com/star-brite ... antifreeze
