Have to frequently adjust Ooogah horn to make it work.
ivaldes1
Topic author - Posts: 960
- First Name: Ignacio
- Last Name: Valdes
Hi, I have a Model A Ooogah horn. I have to frequently turn the adjusting screw on the back to make it work. Is there a way to fix it so that it works most of the time?
Jim_PTC_GA
- Last Name: Fisher
- * REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
Re: Have to frequently adjust Ooogah horn to make it work.
The one I use is also an old A horn and had the same problem. I discovered through trial and error that I needed larger wire in the whole circuit for the horn. I did disassemble the horn and clean / lubricate first. Then later discovered it needed larger wire.
Just give me time to Rust and I'll be good as new.
Wabi-Sabi
- Last Name: Humble
I agree with Jim, my limited experience with a fussy weak model A horn was electrical, not a mechanical fix.
John Illinois
- Last Name: Burgett
I agree. sometimes a relay helps.
John
John
Jim Eubanks
- First Name: Jim
- Last Name: Eubanks
I have found that lubricating them does wonders.
Inthegarage
- Last Name: Mosher
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster pick up
Have you tried the horn with the rear cover off ? If it works you are tightening the screws to tight. Do you know there’s a adjustment screw behind the cover
Let us know
Let us know
ivaldes1
- Last Name: Valdes
Here are some photos. If I use a larger gauge wire (red one in the photo) and directly jump it to the terminal block it works fine sounds strong. Using the switch it is weak. If I 'revive' it using the larger gauge wire it is better for a few toots on the switch but then goes back to being weak.
Sarikatime
- Last Name: Seress
Clean to bare metal on each side of the head bolt and the bracket to get really good ground. Or install a second ground wire. Just a thought. Frank
Erik Johnson
- First Name: Erik
- Last Name: Johnson
In addition to lubricating the bearings as others have mentioned, clean the commutator. I like to use a Q-tips sprayed with electrical contact cleaner to do this.
ivaldes1
- Last Name: Valdes
A screw was loose on the back side of the wire hookup. I tightened it up and it works a lot better now, thanks all!
