Does radiator year matter for early or late front motor mount?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Sun Nov 29, 2020 1:02 am
Hi all, does the kind of radiator or radiator trim matter for using a early or late front motor mount? Specifically 1916 style brass radiator with a late front motor mount?
Re: Does radiator year matter for early or late front motor mount?
Post by Allan » Sun Nov 29, 2020 2:06 am
That should not be a problem. 1917 still had the old type front engine mount, and the new low radiator. The later high radiator fits the same way. The only snag I can think of is the high radiator with deep apron that has the hole to screw to the engine mount will have no place to go.
MWalker
Last Name: Walker
Post by MWalker » Sun Nov 29, 2020 9:28 am
The later mount should work with your brass radiator, but I'd hold out for an early-type mount because they're stronger.
Post by Steve Jelf » Sun Nov 29, 2020 10:29 am
You see lots of parts salads for sale that have brass radiators over 21-27 spring clips. Fit is no problem. But I would go with the earlier clip as Mike says.
Last Name: Hatch
Post by Dan Hatch » Sun Nov 29, 2020 10:46 am
I just posted one for sale. Dan
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster’s,51 Mercury 4 door sport sedan, 67 Mercury Cougar
Post by kmatt2 » Sun Nov 29, 2020 2:17 pm
Because you are using a 1926-27 frame I wouldn't worry about using the late front motor mount you already have. If it bothers you get a early mount, be sure to get the U bolts with it. Good U bolts with good threads are the hardest part to find but out there.
kmatt2
First Name: Kevin
Is your Y front mount part of the original T trailer ? If yes I would keep it, you have worked so hard on using other trailer parts.
Post by Steve Jelf » Sun Nov 29, 2020 2:48 pm
Is your Y front mount part of the original T trailer?
I thought this was about a car. Why would anyone install a radiator on a trailer?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Sun Nov 29, 2020 10:13 pm
Brother Steve, It was a T then it was a hay wagon trailer now it is going to be a T again...
Post by Steve Jelf » Sun Nov 29, 2020 10:42 pm
Excellent! It's always good to see a T resurrected. :)
