Front Spring Perch
SIR TIMOTHY
Topic author - Posts: 110
- First Name: TIMOTHY
- Last Name: ELDER
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout
Front Spring Perch
This Model T front spring perch is being offered on a hot rod site I belong to, he says it was sold through Lang's. Does this bolt to the outside of the frame or is the front crossmember removed and this fits inside of the frame? Tim in Omaha
- Last Name: House
Re: Front Spring Perch
I, ....er, ah,....don’t see a Front spring perch
It bolts to the frame to lower the front axle (perhaps to much).
video https://www.youtube.com/watch?v=V7dni5Z-k2E Some similar methods but not the only
Sean B
- First Name: Sean
- Last Name: Bittle
Definitely a “period correct” way of lowering a T.
If I remember correctly it is in this book. It explains how to make one yourself.
David Mazza
- Last Name: Mazza
- * REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
Super way to lower the front. The completely original Aldrich roadster is one of the oldest known surviving hotrods. Also happens to be at Lang’s! Wish they would get moving on it, they’ve had it a decade and it still isn’t running
SIR TIMOTHY
- Last Name: ELDER
Thanks guys, I knew it bolted to the frame, I just needed to know if it was to the outside or the inside and now I know. Pictures worked great. Tim in Omaha
