I've been working on these for a few weeks, and it's coming together well. My neighbor made an awesome drilling guide on a scrap piece of 1/2" thick aluminum using CNC equipment; it has the 10 locating pin holes, as well as 5 holes I can use to mark the center reference lines and two for the tail shaft. I've got all of the holes drilled 1/8" right now, hopefully I can use a mag drill this weekend and enlarge them to finished size. What's really cool is I can reuse the drilling template.
I used drill bits as shims to square it up to the table top the way I wanted it, then clamped it and drilled away. There is a guide on the side of the jig, but my table has flame cut edges so the shimming was expected. All in all it's coming along nicely.
Building my pan table
Topic author - Posts: 346
- First Name: Gary
- Last Name: London
Re: Building my pan table
Fine looking bit of work, Gary. Good for you.
- First Name: Henry
- Last Name: Lee
Very Nice Gary!
Hank in Tin-A-See
Hank in Tin-A-See
Good start there, Gary ! I took on the same endeavor a number of years ago as the KRW c.c tables are few & far between !
