Anyone had a Spring break at the centre bolt?
Jem
First Name: Jem
Last Name: Bowkett
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
Post by Jem » Mon Dec 21, 2020 5:13 pm
A friend recently hit a pothole. Stopped, couldn't see any damage. A mile later the steering locked up. The front main leaf had broken across the centre bolt hole, the 2 sides worked out of the spring clamps and the front of the car dropped down. Never heard of this before, but it is an obvious stress point for the leaf.
Kerry
Last Name: van Ekeren
Re: Anyone had a Spring break at the centre bolt?
Post by Kerry » Mon Dec 21, 2020 5:34 pm
That's why every town once had a black smith/ spring works. Springs break. :o
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Dec 21, 2020 5:57 pm
I had it happen on a rear taper leaf. Fortunately not the main leaf. Fortunately we have a local spring manufacturer and between us I got a new taper leaf made!!
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Mon Dec 21, 2020 7:11 pm
I replaced a rear spring assembly because the top leaf had snapped in half.
William L Vanderburg
1922 Center Door Sedan
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Mon Dec 21, 2020 7:27 pm
Loose U bolts.
Last Name: Kuehn
Post by John kuehn » Mon Dec 21, 2020 7:45 pm
When T ‘s were used for everyday transportation that was fairly common. But that was over 50-60 years ago or longer.
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster’s,51 Mercury 4 door sport sedan, 67 Mercury Cougar
Post by kmatt2 » Mon Dec 21, 2020 10:19 pm
I have a accessory front taper leaf spring that doesn't use a center bolt. The spring uses upward facing dimples the size of the center bolt head rolled into the spring leafs. I have seen era advertising for this type spring saying, "Avoid broken spring leaf failures with our springs". So your friend's experience is Model T era perfect.
Mike Royster
First Name: Michael
Last Name: Royster
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout 1916 Runabout
Post by Mike Royster » Mon Dec 21, 2020 10:56 pm
When I rebuilt my springs both front and rear had one spring each broken at the center bolt. Welded them up good as new.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Tue Dec 22, 2020 6:26 am
When leaf springs break at the center bolt hole, 99% of the time it is because the center bolt isn't tight enough, and/or the spring clamp isn't tight enough. That lets the spring flex where it shouldn't. There shouldn't be ANY flex in the center of the spring. Dave
1925 mostly original coupe.
Post by Original Smith » Tue Dec 22, 2020 10:55 am
I have two 13's, and both had had the front springs replaced. I wonder if that happened often? I remember it took me over a year to find a good replacement for my roadster, but I finally did. 1913's had two styles of springs, front and rear. Some had the curled leaves and some didn't.
Last Name: Hatch
Post by Dan Hatch » Tue Dec 22, 2020 11:21 am
I have a lot of them over the years. That and cracked front frame members.
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Tue Dec 22, 2020 2:17 pm
I never have a spring break. It seems that we get busy here on the farm about then.
Jem
First Name: Jem
Last Name: Bowkett
Post by Jem » Tue Dec 22, 2020 5:30 pm
:D Herb, the moment I posted that subject line I was waiting for someone to come out with that line!
Post by Rich Eagle » Tue Dec 22, 2020 6:05 pm
Good job Herb. I was waiting for Perry to mention it.
I refrained for some reason.
I haven't had one break there but have seen a few broken ones before.
