technical question about the starter.
Anton Seelmann
Topic author - Posts: 27
- First Name: Anton
- Last Name: Seelmann
- * REQUIRED* Type and Year of Model Ts owned: Touring 19; Speedster 13/Rajo; Pickup 21; Tudor 25; Touring 25/Fronti; Touring 1909
Hi there,
I have a technical question about the starter.
What is the power of the starter (in KW) and what is the power consumption (peak and nominal current).
I am the President of the Ford Model T Club of Germany and a member really wants to know this.
Thank you in advance for the information and a good year 2021 with many fun trips to all members of the MTFCA
Anton Seelmann
Anton Seelmann
Art M
- First Name: Art
- Last Name: Mirtes
Re: technical question about the starter.
The power of a starter depends on the voltage at the starter and the condition of the starter. The input power can be determined by measuring the current flowing thru the starter and the voltage at the starter terminal. The output power depends on the efficiency of the starter, which would require a dynamometer to determine. I have a friend with a small engine dyno and maybe I could get him to measure a starter. I am not sure why I would need to know this other than curiousity. Art Mirtes
I'm nearly certain that Ron Patterson has done this testing and mentioned the results in the past. Hopefully, he'll see your posting and have your answers.
ABoer
- First Name: Anthonie
- Last Name: Boer
Anton ; the starter of a Model T need atleast to lift 11 pound at one foot .
Toon
Toon
jab35
- Last Name: Bartsch
Ron covered this in 2012, see Scott's link for additional info,
"Assuming the starting motor is operating properly on 6 volts it should draw 70 amps free running, 150-160 Amps cranking engine and 450 Amps stalled pushing 12 pounds of torque.
Model T battery cables should be 1/0 with soldered (not crimped) wire terminals.
Ron the Coilman"
Ron the Coilman"
Anton Seelmann
- First Name: Anton
Hello everybody,
first of all, I may mention again how great one is helped in this forum. My special thanks go, of course, to the authors of the contributions (Art Mirtes, Jerry VanOoteghem, Scott Conger, Anthonie Boer, James Bartsch).
Many greetings to all members of the MTFCA from Bavaria / Germany
Anton Seelmann
Anton Seelmann
