canadian 26 coupe sill plates
Topic author - Posts: 28
- First Name: mike
- Last Name: mclean
i have a 26 coupe made in Canada i want a set of sill plates not sure what they look like or if someone has the size of then bought a set from langs but they will not fit on the sill so if someone has a set they will sell or have a picture or the measurements of them let me know you mike
- First Name: Les
- Last Name: Schubert
Re: canadian 26 coupe sill plates
Hi
I have a 26 Canadian coupe, all original sitting outside. I will try to take some pictures. Maybe send me a PM (I assume that is still possible)
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Mike, the sill plates changed over the 26-27 model year. The picture I posted is of a mid year 1926 canadian coupe. There are no reproductions of this one. The material is solid zinc or similar metal. It does not polish up, and is a kind of an unatractive grey. My guess is some young engineer showed Ford his prototype, and Ford swore at him, threw it on the ground and stepped on it, the rest is history.
- First Name: mike
- Last Name: mclean
thanks guys that help alot mike
