1927 Steering Column Attachment
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Post by FundyTides » Thu Jan 07, 2021 6:51 pm
I am just reinstalling my steering column after repairing the loose rivet situation at the top. Guess I wasn't paying attention when I removed the column. There are 2 different length bolts that are used to attach the mounting flange on the column to the lower flange on the frame. I don't see any real reason for this. Did somebody just use a wrong bolt at one time or is there a reason for the difference? If so, which bolt goes where (front vs rear)?
Re: 1927 Steering Column Attachment
Post by RajoRacer » Thu Jan 07, 2021 7:38 pm
Should be same length bolts for the bottom.
Post by Mark Gregush » Thu Jan 07, 2021 8:56 pm
And don't forget the wood block. ;)
Post by Norman Kling » Thu Jan 07, 2021 9:09 pm
There should be two shorter bolts at the bottom heads up nuts down. A wood block above the two bolt heads and a longer bolt through the top of the bracket, wood and frame. All three have castle nuts with cotter pins.
FundyTides
First Name: David
Last Name: Wilson
Post by FundyTides » Thu Jan 07, 2021 9:50 pm
OK. That's what I thought. I'll go through my box of T bolts. If I can't find one, I'll cut and drill the long one. Thanks for the info
