Where do these go?
Mopar_man
Topic author - Posts: 1158
- Last Name: Govoni
Where do these go?
Need some help with a screw set for a 26/7 touring. I bought a pack of interior trim screws at Carlisle a while back and I'm trying to figure out where they go. As far as I can tell the 7 circled in blue are for the dashboard to the cow. The ones circled in orange were ordered from Lang's and Are for the switch plate. I'm thinking that the ones in green are for the switch plate as well (they came in the kit) but they seem a bit bigger. The two circled in red I'm not sure. Any suggestions? Do the dash screws have to have cup washers just under the screw head?
Here is the packaging.
AndreFordT
- First Name: Andre
- Last Name: Valkenaers
Re: Where do these go?
This are the screws and nuts that fix the dash to the body.
7 are needed
Andre
Belgium
7 are needed
Andre
Belgium
Mopar_man
- Last Name: Govoni
Any Idea about the ones in Red?
doodlebugt
- First Name: Bruce
- Last Name: Csorba
- * REQUIRED* Type and Year of Model Ts owned: 1915 4 spring Rajo racer, 1917 C-cab van, 1925 Dalgety tourer
Column clamp.
Bruce
(Are they originally shorter?)
Bruce
Bruce Csorba
Melbourne, Australia
15 4-spring Rajo racer
17 C-cab van
25 "Dalgety" Tourer
17 C-cab van
25 "Dalgety" Tourer
Mopar_man
- Last Name: Govoni
Thanks that makes sense.
Green and Red ones for the column clamp.
varmint
- First Name: Vernon
- Last Name: Worley
I have yet to purchase some. Should they be oval or flat head?
Vern (Vieux Carre)
- Last Name: House
Column clamp ?.. oval
All are single slot, oval head, nickel plated. Except Canada, those are Robersons.
Stainless look like nickel when polished and won't nickel tarnish
Mopar_man
- Last Name: Govoni
Thanks everyone. This helps. now I see where they all go.
