Hello;
I am restoring a 27 Coupe. While disassembling the steering column and getting pieces painted and bolts ready.
The 2 bolts in the attached picture hold the lower bracket of the steering column to the dash. As you can see they appeared to be originally Nickle plated. Can anyone confirm if they are to be Nickle plated?
Thanks Steve
Nickle Plated or Not
Re: Nickle Plated or Not
Looks like 5 out of 5 do - one old photo. Could be the same screw size for the Ignition Switch Panel
On our Canadian sourced cars I believe they were nickel plated, BRASS, and often Robinson head screws.
Allan from own under.
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Yes. On my Canadian 27 Touring they are nickel platted Robertson head.
- First Name: Alan
- Last Name: Long
My December 1926 has Nickel Bolts as shown affixing that bracket as well along the top of the “dash”
All have the standard screwdriver slot. No Robertson on them or the Steering Wheel.
Alan in Western Australia
