What is this for?
Topic author - Posts: 6384
What is this for?
Spacing of the corner holes is the same is early front spring clip
- Attachments
- w4.png (292.18 KiB) Viewed 2370 times
- Last Name: Warren
Re: What is this for?
I would say it is a front spring clamp plate that can be used for early and late cars
It could well be from a horse drawn light jinker.
It was an accessory front spring clamp bar - apparently, the earlier double u-bolt bracket was a "better idea" !
Spring Plate, added strength to front crossmember to help prevent front spring breakage.
- Last Name: Patrick
Dan, you are a virtual cornucopia of knowledge.
I thought it might be used to lower the front end by flattening out the arc of the front spring. Maybe a lower front end was thought to be more trendy and sporty. Jim Patrick
Thank you for the ad - explains the purpose
- Last Name: Matthiesen
I have one on a TT chassis that saw hard use. Original pictures of TT's at work will sometimes show these.
- Last Name: Clements
My 26 Coupe has one on it.
