Ac brakes
Topic author - Posts: 51
- First Name: Matthew
- Last Name: Cooper
Ac brakes
I’d there anyone still making the ac brakes and linkage kits ?
- First Name: Mario
- Last Name: Brossard
Re: Ac brakes
Sure Larry did. I have 2 sets from them. Work perfectly. Super Mario Bross and Chuck Norris approve!
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- Last Name: Cooper
Re: Ac brakes
Thank you, i don’t like the rockys that Snyder’s have since they don’t work in reverse and disc kits don’t look well on a 100 year old car. I hear these work well . Anyone still making the linkage set up ?
Re: Ac brakes
Rich Baughman. http://www.mtfca.com/discus/messages/59 ... 1468453589
- Last Name: Cooper
Re: Ac brakes
Thank you !
- First Name: Mario
Re: Ac brakes
Linkage Made by Richard
His name is Richard Baughman
3771 Auburn Folsom Rd.
Loomis CA 95650
916-652-7827
He makes a very good product and will work with you if you need help.
Loomis CA 95650
916-652-7827
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Mario
Re: Ac brakes
Also he's email: richandbertie@gmail.com
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- Last Name: Cooper
Re: Ac brakes
Perfect, thank you
- Last Name: Cooper
Re: Ac brakes
Unfortunately Richard is not making linkage kits at this time. He says hopefully in the near future he will be able to start up again. Is there anyone else making linkage?
Re: Ac brakes
If you are handy and inventive, you can make your own cable setup like the originals.
- First Name: craig
- Last Name: leach
Re: Ac brakes
John @ Model T Ranch makes a equalizer very simular to the rocky mountain one. I made my own equalize for the A-Cs on my speedster ( pull type instead of push) and used chebby E-brake cables so I had an adjustment for cable length. I took them off & made rods for them the only differance I found was the rods rattle and the cables didnt. Unfortuneatly I gave the cables away.
Craig
Craig
- First Name: Danny
- Last Name: Deaton
Re: Ac brakes
Does anyone have a picture of Richard’s linkage bolted to a frame? I like the looks of his crossbar but hard to picture where it would bolt to the frame.
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 RHD Canadian Touring 1916 Pickup 1926 Fordor 1925 Dalgety Tourer 1916 Speedster
Re: Ac brakes
http://www.mtfca.com/discus/messages/17 ... 1314393335
http://www.mtfca.com/discus/messages/599638/623576.html
some great previous posts on Ac brakes, and also fantastic original Ac brochure images on Google.
I think the original cable operation set up should serve you well.
- First Name: Danny
- Last Name: Deaton
Re: Ac brakes
I like Richards setup and may try to recreate it. I have a ton of stuff in the way and if I can get those control rods outboard of the frame it would work out for me.
Re: Ac brakes
Or just keep it simple and use cables like the ends of the levers on the brakes would be setup for. Look at Sunday swap meet on the classifieds page. The top item shown is the link between the cable pulley and transmission pedal.
- First Name: Danny
- Last Name: Deaton
Re: Ac brakes
I have a aux transmission in the way of bolting that to the drive shaft
Re: Ac brakes
I made something like this for my rocky Mtn but with a few changes could work. Instead of the 26/27 brake arms I just used flat plate for the cross bar;
http://www.mtfca.com/discus/messages/33 ... 1384711491
You could mount pulleys with a cover over them so the cable would stay in place on each end of the cross bar and would go around the transmission. If you have the newer style replacement AC's that use rods and clevices then just use them.
Re: Ac brakes
The best way is to do the job the way AC did it, not the way it's currently done with rods.
- First Name: Danny
- Last Name: Deaton
Re: Ac brakes
You cannot use the stock ac setup with a aux tranny as the tranny is in the way of the cables can you? I haven’t dug into mine yet to mock-up but only looked at you all’s pictures.
