more 26/27 fuel tank mounting questions
Topic author - Posts: 732
- First Name: Danny
- Last Name: Deaton
firewall pad. Cardboard or something a little more water resistant? You guys make your own or purchase?
- First Name: Adam
- Last Name: Doleshal
Re: more 26/27 fuel tank mounting questions
Wow! Never knew anyone reproduced that AND I’m very surprised it is only $25! I’m replacing the tank in a ‘27 Tudor next month and will be ordering one!
- First Name: Danny
- Last Name: Deaton
I will post a pic when I get mine.
That molded fiberboard gas tank insulator for the '27 cars is a very nice reproduction, fits fine. The earlier Improved Car just used two strips of webbing that were riveted at 4 places to the cowl. You can tell if you car is later, as those tiny 4 holes will be missing from the upper face of the cowl.
- First Name: Danny
- Last Name: Deaton
Thanks Dan
That’s awesome
That’s awesome
- First Name: Vernon
- Last Name: Worley
Anyone have a photo of the two webbing strips (2917) mounted in the cowl?
I need to see whether I need to order 2917 or 2918.
Thanks!
Thanks!
Vern (Vieux Carre)
These should help you, pieces for all but Fordor:
All '26-'27 used webbing pads above the tank.
Only some '26 used webbing pads behind the tank. You can tell by holes punched in the cowl face for these pair of pads.
The later 26-27 did away with the two webbing cowl pads, and used the molded fiberboard insulator.[/b]
All used the rubber insulator strips on the support rods that hold the tank in place.
- First Name: Danny
- Last Name: Deaton
So I can now say I have a 26 - not a 26/27?
- Last Name: Worley
Excellent info. I did not even know they were there to begin with 'cause it had nothing.
I see now that even my question was wrong. Finally got 2917, 2918, and 2918A straight.
Thanks again.
Thanks again.
Vern (Vieux Carre)
