1915 Magneto Output Post
Topic author - Posts: 72
- First Name: Victor
- Last Name: Foster
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1915 Touring
- Board Member Since: 2002
I've wanted to purchase the fun projects magneto output post for my 15 car, but alas they are no longer available. With that in mind, does anyone have the drawings of them so I could make one for my car.
- Last Name: Wrenn
Re: 1915 Magneto Output Post
Why not order one from Langs or Snyders or Chaffins?
If the one you are looking for is with brass post, have you checked the suppliers to see if they have one in stock? https://www.modeltford.com/item/3260E3.aspx
On the other hand, the replacement style would work fine. The only one to see it would be you with the floor boards off. The catalog list it for 17 -25 but should work fine for pre 17's too. Brass is conductive, so you would need to insulate the center pickup from the housing, not to mention sourcing/making the spring loaded pickup. Guess you could gut parts from a later style to use.
- First Name: craig
- Last Name: leach
Victor I think I have a new one out on a front oiler kit?
