In this original engineering drawing, there is a Head Lamp Dimmer T8892 shown for a non-starter vehicle. This is used with the steering column mounted horn button/light switch combination for non-starter cars(1917-1922 ?). I’m thinking it’s a relay to step up the power to the headlamps when the switch is moved from normal(dim) to bright position.
I'm looking for more information on this part. 1) Does anyone know anything about this item? 2) Does anyone have a Mod T with one on it? 3) What would it consist of for possibly duplicating it? 4) If anyone has one would they be willing to sell it?
Non Starter Vehicle Wiring Question - 1918
- Last Name: Strange
Re: Non Starter Vehicle Wiring Question - 1918
http://www.mtfca.com/discus/messages/179374/200361.html
http://www.mtfca.com/discus/messages/29 ... 1178994052
http://www.mtfca.com/discus/messages/25 ... 1332693652
https://www.google.com/search?q=dimmer+ ... e&ie=UTF-8
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
The "dimmer" is actually an inductor placed in series with the headlights.
It acts like an AC resistor to the magneto AC voltage.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Corey Walker
- First Name: Corey
- Last Name: Walker
There are actually two separate coils in the one unit. They both knock down the voltage so the headlights don’t burn out. The bright wire goes to one and the dim to the other, the single wire goes to the headlights to be wired in series.
LEW1918TT
Topic author - Posts: 6
- Last Name: Walla
- * REQUIRED* Type and Year of Model Ts owned: 1918 One Ton, 1920 Runabout, 1924 Tudor
Thank you for the links to prior discussions.
LEW1918TT
- Last Name: Walla
Thanks for the pics. Now I know what one looks like I can look for one. If you know of any for sale please let me know.Corey Walker wrote: ↑Tue Feb 23, 2021 9:33 amThere are actually two separate coils in the one unit. They both knock down the voltage so the headlights don’t burn out. The bright wire goes to one and the dim to the other, the single wire goes to the headlights to be wired in series.
