Wanted: front axle repair
70boss2wv
First Name: Leonard
Last Name: Hochendoner
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup
Post by 70boss2wv » Thu Feb 25, 2021 1:41 pm
I have a 27 that needs upper and lower king pin inserts on the right side.
I don't have the tools, so I would need to buy all that just for one repair.
It would suit me better if I could bring the axle somewhere and have it done.
I can remove the axle and bring it to a shop within a couple hundred miles or so.
My zip is 26105 (Parkersburg, WV; Marietta, OH) area.
PM or email or call (304) two nine 5 - seven seven 2 four.
Adam
First Name: Adam
Last Name: Doleshal
Re: Wanted: front axle repair
Post by Adam » Thu Feb 25, 2021 2:04 pm
If it’s actually a ‘27 axle, they are typically quite a bit harder and odds are you might just end up breaking the tapered reamer. They can be kind of dicey to use the Stevens tooling on unless you are quite experienced. My recommendation would be to find a better axle.
Last Name: Hatch
Post by Dan Hatch » Thu Feb 25, 2021 8:44 pm
Check your email. Sent a contact of someone close to you. Also you ship them by ups. Not to bad depends on how far. Dan
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Fri Feb 26, 2021 8:09 am
I have the same need as Leonard with my '26 Runabout's front axle. I have searched, unsuccessfully, my contacts in eastern Nebraska for someone who can do the repair. I can send it to Model T Haven for repair but I would like to find someone within a few hours drive.
If anyone in eastern Nebraska or western Iowa wants to earn some cash, send me a PM or email through the forum.
Sorry for hijacking your thread, Leonard.
70boss2wv
First Name: Leonard
Post by 70boss2wv » Fri Feb 26, 2021 9:24 am
Mark,
Not at all, that's what it's for. The more the merrier.
The more attention this thread gets the better the chance we all get our axles fixed.
Also, you may want to see my post under parts, for a sevens axle tool.
You may see some useful information or options there.
Last Name: Hatch
Post by Dan Hatch » Sat Feb 27, 2021 4:44 am
I repair front axle. Install Stevens. Inserts, weld and face the yokes also straighten. Will also install and machine bushings in spindle. My zip is 35173. Thanks Dan
Post by Scott_Conger » Sat Aug 14, 2021 10:35 pm
worthy of a bump
JWalters
First Name: Jason
Last Name: Walters
Post by JWalters » Wed Sep 29, 2021 6:22 pm
Bump to top
FreighTer Jim
Last Name: Jarzabek
Board Member Since: 2008
Post by FreighTer Jim » Sat Oct 09, 2021 6:25 pm
Bump ….
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
