Model T in 1914-Old Photo
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Wed Mar 03, 2021 10:38 pm
Notice the headlights.
Benji
First Name: Benjamin
Last Name: Eckstein
* REQUIRED* Type and Year of Model Ts owned: 24 Roadster Pickup, 13 Runabout, 13 Touring, 14 Light Delivery, 15 Speedster
Board Member Since: 2012
Re: Model T in 1914-Old Photo
Post by Benji » Wed Mar 03, 2021 10:50 pm
Looks like a 1913
Post by Steve Jelf » Wed Mar 03, 2021 10:52 pm
I think they're normal pre-1915 gas headlights, aren't they?
Kerry
Last Name: van Ekeren
Post by Kerry » Wed Mar 03, 2021 10:58 pm
Looks to me like reflector and globe.
Post by Allan » Thu Mar 04, 2021 1:22 am
The forward folding top windscreen is usually associated with 1913 models. The headlights look like Brown lights, fitted with full reflectors and globes.
But the cation does not lie. The car has 1914 tags.
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Post by BHarper » Thu Mar 04, 2021 2:44 am
Hi Steve and Kerry. I think that both of you are right.
If we look carefully at the headlamps, the top of the smoke bonnet can just barely be seen behind the headlamp rim/ headlamp door. These ARE gas lamps.
There is no gas burner to be seen and no Mangin mirror either as they have been replaced with one of the aftermarket kits available at that time.
These kits provided you with silvered reflectors, bulbs, wire, and a switch to convert your lamps from gas to electricity. Also note the position of the lad standing on the running board at the driver's side. He is standing just about where the gas generator would be mounted, suggesting that it has been removed as it is no longer needed by the now electrically powered lamps.
The advertisement for the "Improved Lighting Outfit" shows the kit which is my '14 touring and was likely installed by the original owner of the car, along with a few other period accessories to make touring more pleasurable.
The Improved kit permits the bulb to be accessed from the rear of the reflector, for replacement when necessary. The lower cost units require that the reflector be removed from the headlamp door/rim to access the bulb from the front, which is inconvenient at best and risks dropping and breaking the lens.
Bill Harper
Keene, New Hampshire
RichJ
First Name: Rich
Last Name: Jesteadt
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
Post by RichJ » Thu Mar 04, 2021 4:50 am
Is there by any slim chance any one has any of these up grade headlamps in there colection
I would be a buyer !!!! Rich J 561 262 0393 or the modern teckey ways
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Thu Mar 04, 2021 9:28 am
My 1912 has had Mag lights since 1915 installed by Dr Bond at a cost of $3.25 . The reflector clips into the original lamp rim,the burner is removed to allow clearance.
