Kill switch
Topic author - Posts: 361
- First Name: Bob
- Last Name: Shirley
Kill switch
Is it ok to ground the mag to kill the motor on the test stand?
- First Name: Jim
- Last Name: Sims
- * REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Re: Kill switch
Should be fine. about 90 percent of all mags are shut off by grounding them.
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Kill switch
You would do better to shut it down by leaning out the mixture at the carb and leave the mag alone.
Re: Kill switch
Pull choke full on. if you dont want to lose your carburator adjustment.
- First Name: Corey
- Last Name: Walker
Re: Kill switch
I never use a battery so before I found a coil box with a switch on the front, i ran a wire from the mag post to a house light switch to turn it on and off.
- Last Name: Hatch
Re: Kill switch
Find a single pole double throw switch and you can run mag or battery. Dan
- First Name: Kevin
- Last Name: Matthiesen
Re: Kill switch
I see that you are set up to kill the mag to the back of the engine. That may be ok, but for a more positive shut down I would just use a alligator clip at the mag post to attach the coil box wire to the mag post. For shit down just unclipt the wire from mag post. The original Ford switch was, on / off, not mag to ground.
- First Name: Hal
- Last Name: Schedler
- * REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Re: Kill switch
Don't ever allow battery current (DC) to go to the magnito post. Just break the circuit to kill the engine
