Roadster versus Roadster pickup bodies
Topic author - Posts: 250
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
From what I have seen the 26-27 roadster had a metal floor under the turtle deck . Did the 26-27 roadster pickup also have that metal floor under the wooden floor in the bed? My 26 body came out of a pasture and I believe it was a roadster and I found a pickup bed as I had no turtle for it. It has rust out behind the body in the sides about 2 1/2 + or -that run lengthwise below where the turtle set and a metal floor. Were these sides on the pickups also? If I were to build a wooden box for it , would those pieces be needed? My metal box needs work and the right top has had something dropped across it and bent it down a little. Thanks
- Last Name: Pharis
Re: Roadster versus Roadster pickup bodies
The metal panel was attached to the sub rails in ‘26. ‘27 had open sub rails and the trunk floor was attached to the turtle deck. I have never had a pickup... but I have no reason to suspect that Henry would produce separate variants for the 2 cheapest models of car
- Last Name: Brown
By eliminating the metal floor it would have been a cost saving where the pickup had a wood floor in the bed. Does anyone make the side rails?
