Model T 26-27 Wire Wheel vs Model A Wheel
Mr. T Ford
Topic author - Posts: 49
- First Name: Bill
- Last Name: Tofeldt
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe & pickup
Model T 26-27 Wire Wheel vs Model A Wheel brancaccio
This posting was originally in the parts for sale forum but I thought the information needed preserving so have moved it to the general forum.
Chris
Model T 26-27 Wire Wheel For Sale $110 Or Best Reasonable Offer.
Chris
J1MGOLDEN
- Last Name: Golden
Re: Model T 26-27 Wire Wheel For Sale $110 Or Best Reasonable Offer
That looks like an early 1928 wire wheel.
Not an A wheel. It lacks the outward pressings between the stud holes, added to strengthen the hub area.
modeltspaz
- First Name: Mike
- Last Name: Spaziano
The very early "AR" wheels lacked the webs between the mounting holes until that design began to experience cracking where the wheel flange meets the tube for the hub, much like some have experienced with 4.50x21 wire wheels used on mid- '25 - '27 Ts.
This problem was remedied by stamping webs in the mounting flange that we are familiar with on the mid '28 -on wheel design giving greater strength in that area. This small design change remedied the cracks in that area due to flexing.
The wheel above looks like a late production (mid '25-'27) Model T wheel to me.
- Last Name: Hatch
The hub cap hole is bigger on the early A wheel than T. Other than that they look alike. Dan
TFan
- First Name: Jim
- Last Name: Riedy
Something I have wondered about. Is the bolt pattern the same for the AR wheels as the T or are they the same pattern as the later A's And while I'm wondering what did the AR stand for? Jim
http://www.mtfca.com/discus/messages/59 ... 1471302865
By Hap Tucker in Sumter SC on Monday, August 15, 2016 - 07:14 pm:
It is very easy to put the Model A Ford wheels on the front of a Model T Ford. Just install the Model A Hub and bearings (they fit fine). And as shown in your the photo make arrangements to lock the front wheel nut once the bearings are adjusted...... If you want to install the Model A hub cap on the wheel you need to do something because the Model T spindle is quite a bit longer than the Model A spindle. You could shorten the T spindle, put good size hole in the hub cap or even attach the hub cap to the spindle between the two nuts and don't allow the hub cap to touch the wheel. Note the Model A brake drum can be turned down if needed to clear things.
...... By the way the bolt pattern is actually a 5 inch on the 5 lug Model A wheels for all Model A car wheels. From the first 1928 AR style to the normal later 1928-1929 style to the 1931 style.
See the page at: https://www.randpcarriages.com/help-sec ... lt-pattern for how to measure the bolt pattern size.
The hub bolt pattern is 5 inches on the 1926-27 Model T wire spoke wheels.
See: http://www.mtfca.com/discus/messages/118802/137012.html
For a comparison of the Model A and Model T wheels. It also has a photo of the AR Model A wheel which look very similar to the standard Model A wheel.
And below is an illustration from the Model A Ford Service bulletins on the difference between the 1928 AR wheel and the later 1928-29 wheel that became standard.
some additional references
http://www.mtfca.com/discus/messages/70 ... 1495319779
http://www.mtfca.com/discus/messages/50 ... 1440458505
ChrisB
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
Moved from classified - parts forum
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
