water temperature gauge
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sat Apr 03, 2021 9:11 pm
Does anyone run a aftermarket temp gauge, and if so where do you put the sender? I see Mac's sells a water inlet with a threaded boss on it.
Re: water temperature gauge
Post by RajoRacer » Sat Apr 03, 2021 9:40 pm
I drilled out & tapped the block's rear core plug to 1/2" p to accept the sender.
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Sat Apr 03, 2021 9:51 pm
My 26 came with one. The sensor is drilled into the side of the head.. I wish they didn't do that, but that's the way it came. With a decent working radiator, there is no need to monitor the temperature that closely.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Apr 03, 2021 9:55 pm
The best spot is here Danny!
Hank
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sat Apr 03, 2021 10:08 pm
I like the cutaway head! That’s awesome
Post by Mark Gregush » Sat Apr 03, 2021 10:19 pm
The water inlet is on the left side of the block where the cooled water is coming in. You would want it at least in the water outlet on the head to see how hot it getting.
Post by TRDxB2 » Sun Apr 04, 2021 12:43 am
There have been several discussions on where best to measure water temperature. Water inlet temp is the water cooled by the radiator. Measuring te output temperature with an adapted outlet water neck or "MotoMeter" is also an option. Some have suggested that the true temperature is towards the rear of the head because of poor circulation. The reality is that all three are somewhat related so if one is higher than it should be it would follow that the others would be excessive as well. The accepted value for output water temperature is around 180 dF.
Not sure of your objective in wanting to add one is, but your choices are either mechanical or electrical sensor (6volt?). Reviews seem to favor mechanical for accuracy but routing isn't as convenient as one with an electrical sensor. Careful on looking at "electrical" as often they are mechanical and are referencing the bulb to illuminate it.
I would take the simplest & least expensive route: water inlet and purchase an automotive temperature scanner. After measuring an acceptable operating temperature you can then relate to the water inlet temperature. All depends on why you need to be so accurate.
Some references
http://www.mtfca.com/discus/messages/33 ... 1378918240
http://www.mtfca.com/discus/messages/70 ... 1492708160
http://www.mtfca.com/discus/messages/82 ... 1546202237
Post by Allan » Sun Apr 04, 2021 3:29 am
I wonder what one would do with the intelligence obtained with a gauge. My T's tell me when they get too hot, usually only when they are low on water for some reason or other. The indication usually shows up on the windscreen!
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Post by Plankhill » Sun Apr 04, 2021 4:58 am
I have a Motometer and a sensor in the water inlet to the block. That tells me if the radiator is doing what it is supposed to do.
Brian D
First Name: Brian
Last Name: Dowell
* REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
Post by Brian D » Sun Apr 04, 2021 6:44 am
Where you aware the MOUSE plug was in the head when you cut it?
Never would have occured to me a plug like that.
I guess you could flush forever and not get that out.
Life is Good, be nice.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Apr 04, 2021 7:01 am
The engineer gave his life! LOL
I did multiple temperature checks over the years and found there is a heat eddy right where I marked it. You really want "True" head temperature when it comes to engine performance. As another find, MotoMeters are off by up to 10-15 degrees. Just in my observations.
All the Best,
Hank
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sun Apr 04, 2021 9:02 am
The wall thickness on the head is a lot less than what I would picture in my head. But I have a lot going through my head😳
Hank, I should have thought about this before we bolted the head down
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Apr 04, 2021 11:14 am
To easy to do it even with the head on. Vacuum cleaner and pilot drills working your way up.
Hank
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Apr 04, 2021 11:40 am
Danny, mid 1920s motometer came out with steering column mounted water gauges and also dash gauges. This may be an idea for a period item. This dash type is on eBay right , looks complete. It’s nice if the seller will drop the bulb in a cup of hot water to see if it works. Otherwise a crapshoot.
Post by RajoRacer » Sun Apr 04, 2021 11:58 am
Here's the original Boyce Motometer water temperature gauge on my Racer - it was marketed for the Model A Ford with a round steering column mount & 2 ways to attach the sending unit - one was in a special head bolt and the other was a contraption for the upper radiator hose -I chose to mount the sender in the block. This unit has a small arm that will lean on the needle when things begin to get too hot and a "Red Ball" shows up - totally cool !
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Sun Apr 04, 2021 12:02 pm
Here is what I did on my speedster.
I had an old Nims style ‘26-‘27 water pump that was missing the impeller and shaft. I tapped the impeller hole in the housing for pipe thread to accept the fitting of the temperature bulb. Seems to work well. It uses a modern dash mounted temp gauge.
John Codman
Last Name: Codman
Post by John Codman » Sun Apr 04, 2021 12:05 pm
As to the OP - the water inlet would be just about the worst location possible for a temperature sender. The water inlet will have the coolest water in the system. The sender ideally should be in the water outlet in the head.
FordFool
First Name: Don
Last Name: Kirtley
* REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
Board Member Since: 2009
Post by FordFool » Sun Apr 04, 2021 12:17 pm
I drill and tap the outlets. I have both mechanical and electrical units on mine. Don
