Cross shaft the same for all years??
Barry Loucks
First Name: Barry
Last Name: Loucks
* REQUIRED* Type and Year of Model Ts owned: 13, 22
Post by Barry Loucks » Sun Apr 04, 2021 8:57 pm
Are the cross shafts for the shifter/emergency brake the same design for each year of model T, perhaps excluding 09?
Mine has a bit of wear under the pillow blocks. I might try to find a better one.
Barry Loucks
Re: Cross shaft the same for all years??
Post by RajoRacer » Sun Apr 04, 2021 9:41 pm
The cross shaft is the same - the clutch throw-out arm/leg or whatever you want to call it was cast into the late ??? teens - later production was stamped. Some "early" brake lever handles utilized a key & pin.
Post by speedytinc » Sun Apr 04, 2021 9:46 pm
EXCEPT. Dont accidently get one from a TT. Cam is quite a bit taller
Post by Allan » Mon Apr 05, 2021 2:32 am
Perhaps an easier fix is to braze the worn sections on the shaft and file them back to fit the pillow blocks. That way you will custom fit them to each other and you will have a bronze bearing in a steel carrier, like having a bronze bush to take the wear.
Post by Wayne Sheldon » Mon Apr 05, 2021 4:43 am
"EXCEPT. Dont accidently get one from a TT. Cam is quite a bit taller"
And some are a slightly different angle I discovered after cutting a TT one down for one of my cars! I was able to heat it and bend it enough to correct the issue, but confirmed the difference with another TT cross shaft I had. It did make adjusting the clutch interesting.
Also, Ford began replacing the cast cams with stamped ones in 1915, although cast cams continued to show up for quite some time.
Barry Loucks
First Name: Barry
Last Name: Loucks
Post by Barry Loucks » Mon Apr 05, 2021 6:07 am
Thanks for the feedback. I’m tempted to try the braze and file fix, just don’t have a good record for making anything round with a file in my hand. The pillow block has some wear too, I forgot to mention.
I’ll watch swap meets when we go back, and keep an eye out for the TT style.
Post by Allan » Mon Apr 05, 2021 6:16 am
Barry, this is one fix where precision is not called for. Besides, if you just file to get a start, then add some paint/blue to the brazing, the pillow block will then show up the high spots. You jut need to keep filing off the indicated spots until the block slides over the bronzing. Let the block be the guide. That way wear in the block is compensated for too.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Fri Apr 09, 2021 5:17 am
What Allan said. As a past customer once said to me when I was welding up some worn out Link Belt dragline track pads, "It's just a f*****g old dragline, not a Swiss watch". Words to remember when trying to over think things. :roll: Dave
1925 mostly original coupe.
Post by Original Smith » Fri Apr 09, 2021 10:10 am
Don't forget the handle! The early ones are shaped different.
