Some pictures of the top frame that came with my 15 Runabout.
Is it the right frame?
Do I have it on backwards?
MY 15 RUNABOUT TOP FRAME
- Last Name: Humble
Re: MY 15 RUNABOUT TOP FRAME
The front bow comes out of the lower piviot and is moved to the higher piviot when in the up position. Reverse procedure to lower the top.
Topic author - Posts: 132
- Last Name: Cox
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout, 1925 Pickup
Thank you Jeff that's what I needed!!
