Has any Forum member purchased this mirror?
If so, I'd like to know how well it works.
Is there something better out there for a 1913 Ford Touring?
https://www.ebay.com/itm/Model-T-Ford-b ... %7Ciid%3A1
Thank you,
Gene
Brass Side-view Mirror
Topic author - Posts: 339
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
- Attachments
- t Mirror.jpg (28.11 KiB) Viewed 2056 times
Gene Emering
Newton, New Jersey
Newton, New Jersey
- First Name: George P
- Last Name: Clipner
Re: Brass Side-view Mirror
I’ve got the black one and real happy very little vibration problems
- First Name: James F
- Last Name: Dix
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1921 Coupe
Many years ago at Hershey, Russ Potter was selling R V mirrors that bolted to the windshield frame using TWO bolts of the windshield hinge. It has been on my '13 Touring since. It stays put, yes, it shakes, but so does everything else. Much less than the clamp style thou. THE BOLT LENGTH IS CRITICAL, so be sure they won't hit the glass. I've bumped it many times, and the windshield it still ok.
Snyder's has it in the catalogue, bracket and mirror separately. (?) I didn't see in Lang's website.
Thanks Russ!
Jim Dix
Somewhere near Big Flats.
Thanks Russ!
Jim Dix
- Last Name: California
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up
For practical reasons, I like them more that any other mirror. I only wish that he used all period correct hardware. But then we can't have everything.
I agree it would be better without the modern hardware, but you can easily replace the Phillips screws and put on a brass cap nut in place of the hex nut.
While a mirror on a Model T may not be rock steady, it doesn't have to be. As long as it shows you what's behind you, you don't need to see the details.
https://www.youtube.com/watch?v=kNhMiW67cmw
My camera held in one hand shakes more than the mirror.
