Demountable rims
Vinny b
First Name: Vincent
Last Name: Bassani
* REQUIRED* Type and Year of Model Ts owned: 1913 touring
Demountable rims
Post by Vinny b » Sun Mar 10, 2019 2:11 pm
What was the first year Demountable rims were offered ?
1913 T touring
1931 A roadster
Re: Demountable rims
Post by Rich Eagle » Sun Mar 10, 2019 2:23 pm
1919 "Demountable rims available as an option, using 30 x 3-1/2 tires all around. Hayes, Kelsey, and Ford supplied wheels, so there were variations in the style. The rims were zinc plated."
From the encyclopedia.
Several manufactures offers different types for Fords earlier.
fliverfan
First Name: Bill
Last Name: Chuplis
Post by fliverfan » Mon Mar 11, 2019 12:56 pm
They are confusing. Best I could figure out was the Hayes and Ford demountable rims are different but still interchangeable with their respective fellows but the Kelsey has removable lugs and requires a different fellow. (And I wouldn't be surprised if got this completely wrong :) )
Post by Steve Jelf » Mon Mar 11, 2019 2:34 pm
Interchangeability depends on the year. At first Hayes, Firestone, Kelsey, Hayes, Ford rims were sui generis. After a few years they were made interchangeable. Details are in the encyclopedia.
Post by Allan » Tue Mar 12, 2019 7:59 pm
On our Canadian sourced cars, demountable rims were all of the loose lug type until well into the 1925 model cars, when fixed lug rims became available.
Loose lug rims of different manufacturers are interchangeable.
Fixed lug rims are a different kettle of fish. I believe Ford and Kelsey rims will fit all wheels taking fixed lug rims. However, Hayes rims, having the foot on the lug, which extends in over the felloe, require a relief in the felloe to accommodate the lug foot, making these rims less interchangable than the others.
Mixing loose lug wheels with fixed lug rims is another thing altogether, as they are designed to wedge on the felloes in different ways.
Vinny b
First Name: Vincent
Last Name: Bassani
Post by Vinny b » Thu Mar 14, 2019 7:09 am
Thank you very much. And electric start was the same year?
1913 T touring
1931 A roadster
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Mar 14, 2019 8:04 am
Electric starter available in 1919 but only for the closed cars.
