Frame Mystery
sweet23
First Name: Darryl
Last Name: Bobzin
Frame Mystery
Post by sweet23 » Thu Apr 22, 2021 10:28 am
I have a frame that appears to be a '25 ( only 2 rivets on on hand brake pawl ) It has a serial number C726397, does the C indicate Canadian? Also the front crossmember is located on top of the side rail instead of above, and the side rail is stepped to allow for this. Can anybody shed some light on this ?
Les Schubert
First Name: Les
Last Name: Schubert
Re: Frame Mystery
Post by Les Schubert » Thu Apr 22, 2021 10:51 am
I would say 1927 Canadian car
Re: Frame Mystery
Post by Steve Jelf » Thu Apr 22, 2021 10:53 am
sweet23
First Name: Darryl
Last Name: Bobzin
Re: Frame Mystery
Post by sweet23 » Thu Apr 22, 2021 11:03 am
Thanks for the info guys ! I had never seen the front of the frame stepped for the crossmember before , and some holes in the frame are different.
Re: Frame Mystery
Post by DanTreace » Thu Apr 22, 2021 6:12 pm
That frame might have been worked on over the years, as the '26-'27 fender bracket that is riveted to the front of the crossmember seems missing. Untold years, untold stories on your frame ;)
Typical Improved Car front crossmember with fender bracket. The 'step' on the top frame rail is for relief went fitting the fender bracket. Extra side holes are for the fender brace that fits to the bracket and for accessory factory front bumper bracket too.
Rivets are later attempt, factory are neater.
Re: Frame Mystery
Post by Allan » Thu Apr 22, 2021 7:10 pm
Darrel, Canadian production allowed for both LHD and RHD, so the later frames have holes for the brake quadrant, steering bracket starter switch, muffler and battery carrier in both frame rails.
sweet23
First Name: Darryl
Last Name: Bobzin
Re: Frame Mystery
Post by sweet23 » Thu Apr 22, 2021 8:29 pm
Thanks, yes I am starting to think it may have had some changes to suit some ones needs. Frame is super nice condition with only mild surface rust. It may end up under one of my cars.
