Oiling cups
tommyleea
First Name: Tommy
Last Name: Russell
Oiling cups
Post by tommyleea » Sat May 22, 2021 3:34 pm
23T..Tie Rod lever oil cups. I am missing the cap off one of my oil cups. It sure looks like there is a hex at the bottom, and it would screw out. But, all the oilers I see are press in. Are they all press in type? Thanks..Tommy
Last Name: Patrick
Re: Oiling cups
Post by jiminbartow » Sat May 22, 2021 4:03 pm
I believe the oilers with the spring loaded cap are tap in. While the oilers (grease cups) with the screw on top are screw in. Jim Patrick
tommyleea
First Name: Tommy
Last Name: Russell
Re: Oiling cups
Post by tommyleea » Sat May 22, 2021 4:10 pm
Thanks..I will have to double check mine now..
Re: Oiling cups
Post by Rich Eagle » Sat May 22, 2021 4:26 pm
Yes, the flip top cups press in. The screw on cups have a threaded base as well as the brass, knurled twist type shown here.
https://www.modeltford.com/i/c/2930001l.jpg
tommyleea
First Name: Tommy
Last Name: Russell
Re: Oiling cups
Post by tommyleea » Sat May 22, 2021 9:31 pm
Thanks.It looks like the hex I am seeing is actually the bolt head, and the oiler presses into the bolt head. Is this correct? Thanks
Last Name: Patrick
Re: Oiling cups
Post by jiminbartow » Sat May 22, 2021 9:38 pm
Can you post a photo? I’m not sure what you mean. If the inside of the hole is smooth, it is a press/tap in. If the inside of the hole is threaded, it should screw in. Jim Patrick
tommyleea
First Name: Tommy
Last Name: Russell
Re: Oiling cups
Post by tommyleea » Sat May 22, 2021 10:38 pm
I will take some pictures tomorrow..
Re: Oiling cups
Post by DanTreace » Sun May 23, 2021 9:12 am
Tommy
The 17-27 tie rod bolts and oilers look like this:
tommyleea
First Name: Tommy
Last Name: Russell
Re: Oiling cups
Post by tommyleea » Sun May 23, 2021 9:22 am
Tommy
That's it right there..Thanks..Now I know..
