I have a full set of original Dayton wire wheels and hubs for my speedster. One of the rear hubs (the left side) is ratty in the taper. The keyway is good, but the taper is oddly worn. Has any one had the taper of a hub rebuilt? And if yes, how and by who?
Failing that, any ideas on where I could find a replacement?
Being in Alaska, it’s very hard to find parts.
Need to rebuild or replace a Dayton rear hub.
Reno Speedster
Topic author - Posts: 609
- First Name: Morgan
- Last Name: Blanchard
Atomic Amish
- First Name: Jason
- Last Name: Kuczynski
- * REQUIRED* Type and Year of Model Ts owned: Antique Vehicle Mechanic at Greenfield Village
- Board Member Since: 2003
Re: Need to rebuild or replace a Dayton rear hub.
Dayton may actually still have it. I have a set of Rudge/Whitworths from a Rickenbacker and they said they could help with those.
Contact them directly and see.
Good luck!
Good luck!
Barnstormers VSC
Si vestri 'non prius novissimo
Celeritate Est Vita
Antique Vehicle Mechanic- Greenfield Village
Barnstormers VSC
Celeritate Est Vita
FordFool
- First Name: Don
- Last Name: Kirtley
- * REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
- Board Member Since: 2009
You might try Jack Putnum. I got a pair of rear hubs from him a few years ago. They are really nice. Worth a try. Don
