Weight of a 1926 Roadster Body
ModelTGal
First Name: Jennifer
Last Name: Pierce
Post by ModelTGal » Wed May 26, 2021 4:15 pm
Hi Folks, wondering if anyone knows the approximate weight of a 1926 Model T roadster body, where everything has been removed. (No steering column, no fuel tank, no interior, no turtle deck, etc)
Mine has some significant rust issues and I want to get the body off of the frame so I can evaluate the issue better and hopefully figure out best corrective actions but I'm wondering how many big burly man-types I will need to corral to get this thing off!!
Thank you
Jennifer
aka ModelTGal
Re: Weight of a 1926 Roadster Body
Post by Rich Eagle » Wed May 26, 2021 5:50 pm
In case someone doesn't have an exact weight to answer your question, I clipped these from:
https://www.conceptcarz.com/s1963/Ford-Model-T.aspx
If my math is right everything but the chassis weighs 830 lbs. Minus fenders, running boards, splash aprons etc and top would give you the weight.
I hope you can get closer than that but if you can't this may help.
Post by DanTreace » Wed May 26, 2021 6:02 pm
Here you go, Ford Sales Data book, Sales Equip. Co.
Post by speedytinc » Wed May 26, 2021 6:13 pm
That weight includes the trunk. As you described, 2 guys can move it around. To walk it off a chassis, 3 guys. One @ each door & 1 in back.
4 guys with 2 long 2x4's recently set a complete town car body onto a chassis for a club member.
Post by DanTreace » Wed May 26, 2021 6:15 pm
Jennifer
BTW, you'll need 4 to do the lift / body drop safely. That is four for the Improved runabout body.
But, for the Improved touring body, best to have six for the lift and drop. ;)
body ready to mount on.jpg (68.59 KiB) Viewed 1934 times
Body Mounted May 8.jpg (65.76 KiB) Viewed 1934 times
Body m painted side view.jpg (55.45 KiB) Viewed 1934 times
ModelTGal
Last Name: Pierce
Post by ModelTGal » Wed May 26, 2021 7:11 pm
Thank you guys! Appreciate the information. (And I loved the picture of y'all picking up the touring body!!)
Now to plan a BBQ or similar and invite some of the local Georgia chapter to "brunch" :-)
Thanks again!
Jennifer
