Removing a gas tank from a 26-7 roadster
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Jun 16, 2021 6:08 pm
It’s been a LOT of years since I’ve done one. Is there some tricks!
I’ve undone the straps.
Getting to the dashboard screws looks difficult!
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Re: Removing a gas tank from a 26-7 roadster
Post by GG Gregory » Wed Jun 16, 2021 7:10 pm
I just did this job last year. You definitely need to remove the dash panel out of the way. And yes those panel screws are a real pain ! After the panel is out the tank should be easy to remove.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Jun 16, 2021 7:18 pm
Thank you for the verification! I was beginning to feel that I was faced with that. This is a project starting with a “field car” so I think I may just drill them out, as I will replace them anyway. A small advantage of a Canadian car as they are Robertson, so the drilling is pretty easy!
GG Gregory
First Name: GG
Last Name: Gregory
Post by GG Gregory » Wed Jun 16, 2021 7:28 pm
Yeah I dreaded the job but luckily all but 1 screw came out sort of easy, you almost have to be part monkey to twist your hands around underneath ! Good luck !
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Jun 16, 2021 9:44 pm
You shouldn’t have to remove or loosen the dash. You do have to remove the floorboards. The info on procedure is in the service bulletins.
George N Lake Ozark
First Name: George P
Last Name: Clipner
Post by George N Lake Ozark » Thu Jun 17, 2021 1:19 am
The Bible says one thing and has pics of a closed car. On my touring. I had to remove dash and screws and one and two screws from the stantions and four bolts from steering column. Discovered and confirmed that the dust. from dash to firewall is different. Open cars are shorter than closed cars.
GG Gregory
First Name: GG
Last Name: Gregory
Post by GG Gregory » Thu Jun 17, 2021 5:25 am
Adam, you DO have to remove the dash panel on a 27 Roadster …been there done that.
John Codman
Last Name: Codman
Post by John Codman » Thu Jun 17, 2021 9:37 am
On my '27 touring I had to remove the steering column. A lot of people have said that you don't have to do this, but after I had everything disconnected, after two separate 1/2 hr attempts to work the tank out, I gave up and pulled the column. I also removed the "instrument cluster" from the dash, but did not disconnect any wires. This is not my favorite model T job.
Ron Horton
First Name: Ron
Last Name: Horton
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1923 Roadster, 1915 Speedster
Board Member Since: 2011
Post by Ron Horton » Thu Jun 17, 2021 10:29 am
Mr Gregory and Mr Codman nailed it. Been there, done that.
I can’t tell if I’m handling life well these days or I just don’t give a sheet anymore :D :D
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Thu Jun 17, 2021 6:52 pm
I was able to install the cleaned gas tank in the 1926 roadster pickup I once had with the dash in. I had to remove the steering gear and the key switch and wires, plus the floor boards were out. Place tank on hogshead and hook the, (prior restored strap lining ), tank straps to cowl hook eye. Now the hard part, even with a helper. Lift the tank up and rotate tank a little if needed to thread the ends of straps threw the fire wall. Now while holding tank up have helper start the strap washers and nuts on engine side of firewall. Don't forget to reinstall the tank drain tube when done.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Thu Jun 17, 2021 9:10 pm
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Thu Jun 17, 2021 9:23 pm
Nope, just have to follow procedures (posted above). Done it probably four times. YES, there is no margin for error and it can be a real pain to get everything in proper alignment, but it can be done.
The coupes and tudors are super easy. The tourings and roadsters are much more difficult, but once you’ve done a couple of them, they aren’t impossible.
Kuhner
First Name: Greg
Last Name: Kuhnash
* REQUIRED* Type and Year of Model Ts owned: 1917, 1921 touring 1927 RPU
Board Member Since: 2006
Post by Kuhner » Fri Jun 18, 2021 8:48 am
The more items out of the way the better. Tough job.
When it’s out consider replacing the welting on the cowl. You can rivet the original way.
“I don’t like nice people. I like tough, honest people”. - Woody Hayes
John Codman
Last Name: Codman
Post by John Codman » Fri Jun 18, 2021 11:26 am
In my previous post I mentioned removing the "instrument cluster" (such as it is) but I did not have to loosen or remove the dash.
Duckwing
First Name: Jim
Last Name: Wilson
Post by Duckwing » Fri Jun 18, 2021 1:40 pm
I tried the instructions but finally removed steering column and dash. Kept jiggling the tank and it mysteriously fell out.
