Ford Fathful oiler with exit tube on the left
Topic author - Posts: 5392
No connection, but something different;
https://www.ebay.com/itm/184918488678?h ... 000%7C7000
Never seen one of these before.
Re: Ford Fathful oiler with exit tube on the left
Perhaps right hand drive ? Be pretty crowded going off the right with the pedals & linkage in the way !
- First Name: Bob
- Last Name: Shirley
I’m betting this was on a counter clockwise marine application. I’ve seen one in my life, the thing ran backwards. I assume the only difference, if they use straight cut timing gears would be camshaft, starter and internal oil line.
If you study the oil capture system, you'll realize it is independent and indifferent to direction of engine rotation.
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
[scott
Are you saying that it would work effectivelygoing out the left?? /size]
The "capture" screened funnel/spillway is facing forward towards the magnets so a considerable amount of oil is captured & directed to the outlet - doesn't matter which side the fitting is - gravity does the rest !
Daniel
Yes, and for the reason that Steve T stated
whether or not an individual finds the left facing outlet a feature or a folly would be up to them
Your observation & explanation was waaaay more "refined" Scott - I didn't mean to interject
Steve
not understanding the embarrass-face...no offense was taken! I articulated a conclusion and you supplied the explanation
