exhaust manifold
AndreFordT
First Name: Andre
Last Name: Valkenaers
exhaust manifold
Post by AndreFordT » Wed Jul 14, 2021 6:06 am
This manifold came with the 1917 two piece crankschaft engine.
Does any know where it was used??
I had one before but it was cracked, this one is in fine condition.
Andre
Belgium
Ruxstel24
Last Name: Hanlon
Re: exhaust manifold
Post by Ruxstel24 » Wed Jul 14, 2021 6:27 am
Andre, that is a manifold for a heater.
All the little dimples are screws for a shroud that goes over it and directs hot air to the floorboard.
I have one too, with no shroud the same as yours.
Post by Norman Kling » Wed Jul 14, 2021 11:34 am
That's correct. It is for a heater. If you use a heater, be sure there are no exhaust leaks or you could bet carbon monoxide poisoning.
Post by TRDxB2 » Wed Jul 14, 2021 12:02 pm
Some pictures of it in use
Heat King on Arvin.jpg (45.05 KiB) Viewed 1253 times
AndreFordT
First Name: Andre
Post by AndreFordT » Wed Jul 14, 2021 12:25 pm
Thanks All,
Great information.
Andre
Belgium
