Mag battery charger
Topic author - Posts: 4946
Mag battery charger
Finished engine magneto puts out 30- 35 volts a/c. Needs a way to keep the 8V battery charged for the starter & occasional evening driving.
Since fun projects isnt available, I built one similar to the one on my 14.
Found an appropriately rated diode in the diode jar(pack rat) and a universal tail light socket. Color coded wires. (didnt have an old wire harness for cotton covered wires) All joints ere crimped & soldered.
This unit attaches to a longer upper steering column bolt.
First try used a 6V dual filament bulb. Put out 4 amps @ speed & blew.(would have worked on a 20-25V output mag)
Second try used a 12v 1157 bulb. Charges 1 amp above idle & 3 amps @ speed. Power goes thru the ammeter, so you can see it charging.
That should be enough to support the starter on day runs.
No effect on the ignition performance on mag.
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Re: Mag battery charger
My set up. Mag to light bulb in back kerosene lamp then through diode to battery
- First Name: Jack
- Last Name: Putnam
John: Where did you connect the red and yellow wires??
To terminal block. Red to magneto terminal. Yellow to yellow/black wire, where wire from generator output goes.Jack Putnam, in Ohio wrote: ↑Thu Jul 29, 2021 12:47 pmJohn: Where did you connect the red and yellow wires??
