Non-Electric Model T Coupe Dash and window trim
Gavin Pocock
First Name: Gavin
Last Name: Pocock
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout, 1918 Coupe and 1925 Delgety Tourer
Post by Gavin Pocock » Wed Aug 04, 2021 7:09 am
I'm interested in any photos of a late 1918 non-electric Model T Coupe dash.
In particular how it is finished off, weather it has a wooden panel under the windscreen or is it left open, is there any trim surrounding the cowl etc.
Also, how the timber edging was finished around the inside of the door, side and rear windows.
Appreciate any assistance here.
Been Here Before
First Name: George John
Last Name: Drobnock
Re: Non-Electric Model T Coupe Dash and window trim
Post by Been Here Before » Thu Aug 05, 2021 10:18 am
Not certain if this will be helpful. The earlier coupes did not have metal trim on doors. The dash would be similar to an electric assist, except the dash would not have an ampere meter.
Gavin Pocock
First Name: Gavin
Last Name: Pocock
Post by Gavin Pocock » Thu Aug 05, 2021 12:40 pm
Thanks for the photo, our dash is a little different to yours, we don’t have a tin panel running across under the windscreen, the ignition key is on the coil box and the light switch is part of the horn button on the steering column.
Post by Rich Eagle » Thu Aug 05, 2021 1:19 pm
Here are links to a photo and feature of a 1918 Ford Model T Pillarless Coupe from smclassiccars.com. Perhaps it will help some.
http://smclassiccars.com/uploads/postfo ... oupe-4.JPG
http://smclassiccars.com/ford/70273-191 ... coupe.html
It might be the same as what they did with the Couplet. This is one from modelthaven.
https://vintagecarsandparts.com/images/ ... g_7270.jpg
1916 coupelet:
http://www.mtfca.com/discus/messages/257047/321724.jpg
http://www.mtfca.com/discus/messages/25 ... 1352788148
Post by Wayne Sheldon » Thu Aug 05, 2021 7:40 pm
The picture George D shows are of a starter/generator 'electric' model T. The wooden framework picture Is clearly of a common pillared coupe. There was a very short time in late 1918, and early 1919 model year T coupes that the starters and generators were not yet ready for the production line. Those few (thousand?) coupes would be 'non-electric' models, in the later (1919 to 1923) style. Otherwise, all non-pillarless coupes were 'electric' models.
Is yours a pillarless coupe? Or a very early pillared coupe?
Gavin Pocock
First Name: Gavin
Last Name: Pocock
Post by Gavin Pocock » Thu Aug 05, 2021 7:55 pm
It has a fixed pillar between the door and quarter window.
