I was told that the Spline fitment was the later version of the P189A shifter, but since I don't see it listed anywhere, I can't really give it a part number other than to suggest if may be a "C" because P189B is the designation (by Chaffin's Garage) for the Pillow Block Left Hand Shifter Lever, so, I'm just going to give it a temporary part number pr P189.
If any of you guys know what the real part number is for this assembly I'd appreciate if you could post it here and I'll make that correction.
***1926-1927 Ruckstell Shifter Lever Assembly***
VowellArt
Topic author - Posts: 584
- First Name: Martynn
- Last Name: Vowell
- Board Member Since: 2012
Fun never quits!
Re: ***1926-1927 Ruckstell Shifter Lever Assembly***
Great Job, Martynn ! I'll pull mine apart again but I don't recall seeing any numbers - there was a casting symbol on the shifter handle, I believe - I'll check.
VowellArt
- Last Name: Vowell
Dan Treace pointed out that the proper designation for the spline shifter is P189-B....don't go expecting to get a spline shifter from Chaffin's Garage under that part number, because that is the number they use for their Pillow Block left hand shift assembly.
Fun never quits!
