Front Axle Rebuilds
SMHnat
First Name: Seamus
Last Name: Hnat
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford T Touring
Front Axle Rebuilds
Post by SMHnat » Mon Mar 22, 2021 11:36 pm
Hi folks. I have tooling for rebuilding front axles and steering assemblies. I check to see if axle is bent, put new bushings in front axle, new bushings in spindles, spindle arm bushings, I can do spring bushings too. Need new wheel bearings? How about a repair on your hub cap threads?
My shop is about 30 minutes north of Detroit, Michigan (via modern car on interstate). It would take about 1.5 hours in a model T from downtown Detroit.
Best way to reach me, Seamus, would be by email at smh.restoration@gmail.com.
Re: Front Axle Rebuilds
Post by Scott_Conger » Sat Aug 14, 2021 10:31 pm
worthy of a bump
JWalters
First Name: Jason
Last Name: Walters
Post by JWalters » Wed Sep 29, 2021 6:23 pm
Bump to top
FreighTer Jim
Last Name: Jarzabek
Board Member Since: 2008
Front Axle Rebuilds
Post by FreighTer Jim » Sat Oct 09, 2021 6:27 pm
Bump ….
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
SMHnat
First Name: Seamus
Last Name: Hnat
Post by SMHnat » Mon Oct 25, 2021 1:00 am
UPDATE:
I will be moving and will be about 1 hour north of Detroit (via modern car). I don't know how to edit post. I can do more than just front axles too. I have UPS shipping account too for cheaper shipping rates if you want I can send you a shipping label to get parts to rebuild to me.
Last Name: Hjortnaes
Post by DHort » Thu Oct 28, 2021 5:10 pm
Seamus,
Pull up your original post. To the right of the headline you will see three boxes. The first one is a pencil. Click on that and you can edit your post.
