Tire Pressure for a 5.25 x 21 ?
Topic author - Posts: 19
- Last Name: Stewart
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Ford Truck
The front tires on my 1924 TT Truck are 5.25 X 21 . What is the proper tire pressure? The rear tires are 6.50 X 20 and say 50 LBS single and 60 LBS dully. Thanks Mark
- Last Name: House
Re: Tire Pressure for a 5.25 x 21 ?
Front tires 32 PSI
- First Name: Dennis
- Last Name: Prince
I run 36 psi in 525/21s on my roadster on wood wheels and 20 psi on my Funster (weights next to nothing) on wire wheels.
Tire pressures recommended by Ford on the T cars and TT trucks, for the 21" balloon tires.
Text above the chart reads to be safe and add 2 or 3 more psi
