Voltage Regulator
Wotherj
Last Name: Wotherspoon
* REQUIRED* Type and Year of Model Ts owned: 1915, 1924, 1926
Voltage Regulator
Post by Wotherj » Fri Aug 20, 2021 12:37 am
Hi everyone,
Dad recently dropped off a box of stuff that I'd long forgotten that I had. In it was a switch panel with what I think is a voltage regulator? It's got 3 wires, Bright, Dim and unknown.
Several questions.
1. Is it a volt regulator?
2. Is it worth salvaging?
3. Can they be repaired?
4. What years would it be relevant for?
Kind regards,
James.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Voltage Regulator
Post by BE_ZERO_BE » Fri Aug 20, 2021 3:30 am
This is an inductor that is used with MAG headlights on non-starter cars.
I would help keep the bulbs from burning out.
Respectfully Submitted,
Be_Zero_Be
Post by TRDxB2 » Fri Aug 20, 2021 10:15 am
It is worth saving and a member is looking for one. The contact wires can be repaired and then it can be tested. A MTFCA member came up with this
Note the insulated wires are thread underneath the wire core, soldering to the windings easily when pulled through. After soldering seal the joint with Flex Seal or Plasti Dip and rethread as shown. The threading is just to protect the wires from pulling loose
Non-Generator Headlight Inductor.pdf
(1.35 MiB) Downloaded 125 times
Post by TXGOAT2 » Fri Aug 20, 2021 11:31 am
Given that the magneto produces alternating current, placing a diode in series with the headlight feed wire ought to cut the power delivered to the lights. I'd like to see a schematic of the OE device.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Fri Aug 20, 2021 1:22 pm
This might help.
Be_Zero_Be
Post by TRDxB2 » Fri Aug 20, 2021 2:00 pm
Identifying the wires to the schematic
wires routing.jpg (35.65 KiB) Viewed 3445 times
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Fri Aug 20, 2021 2:07 pm
Here are the links to the Schematics and Harness Diagrams on the MTFCI web site
Schematics
https://nebula.wsimg.com/3e10aca08d1115 ... oworigin=1
Harness Diagrams
https://nebula.wsimg.com/3a0733937917a1 ... oworigin=1
Be_Zero_Be
Last Name: Strange
Post by CudaMan » Fri Aug 20, 2021 4:39 pm
Someone was just looking for one of those in the classifieds:
viewtopic.php?f=5&t=23001
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Fri Aug 20, 2021 8:25 pm
A diode will indeed cut the power by half. But, an inductor reduces the power with increasing frequency (i.e. engine revs) which is why it is better suited to this application.
Post by TXGOAT2 » Fri Aug 20, 2021 9:27 pm
So, it functions as a choke.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Fri Aug 20, 2021 10:07 pm
More like a variable resistance (actually reactance).
Be_Zero_Be
Don D
First Name: Don
Last Name: Demio
* REQUIRED* Type and Year of Model Ts owned: 1919 T
Post by Don D » Sat Aug 21, 2021 8:29 am
Does anyone know of a commerccial source for the purchase of a Voltage Regulator/Dimmer Resistance Inducer that is compatable for a 1915 T?
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Sat Aug 21, 2021 3:20 pm
The ‘15 Ts did not have a dimmer switch, and therefore no place for the dimming component discussed here. The magneto lights were just on or off, however, they are dimmer at idle and get brighter as the engine RPM increase.
Eric
