Voltage Regulator
Topic author - Posts: 5
- Last Name: Wotherspoon
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1924, 1926
Voltage Regulator
Hi everyone,
Dad recently dropped off a box of stuff that I'd long forgotten that I had. In it was a switch panel with what I think is a voltage regulator? It's got 3 wires, Bright, Dim and unknown.
Several questions.
1. Is it a volt regulator?
2. Is it worth salvaging?
3. Can they be repaired?
4. What years would it be relevant for?
Kind regards,
James.
Several questions.
Kind regards,
James.
- First Name: BOB
- Last Name: CASCISA
Re: Voltage Regulator
This is an inductor that is used with MAG headlights on non-starter cars.
I would help keep the bulbs from burning out.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
It is worth saving and a member is looking for one. The contact wires can be repaired and then it can be tested. A MTFCA member came up with this
Note the insulated wires are thread underneath the wire core, soldering to the windings easily when pulled through. After soldering seal the joint with Flex Seal or Plasti Dip and rethread as shown. The threading is just to protect the wires from pulling loose
Given that the magneto produces alternating current, placing a diode in series with the headlight feed wire ought to cut the power delivered to the lights. I'd like to see a schematic of the OE device.
- First Name: BOB
This might help.
Be_Zero_Be
Be_Zero_Be
Identifying the wires to the schematic
- Attachments
- wires routing.jpg (35.65 KiB) Viewed 3277 times
- First Name: BOB
Here are the links to the Schematics and Harness Diagrams on the MTFCI web site
Schematics
https://nebula.wsimg.com/3e10aca08d1115 ... oworigin=1
Harness Diagrams
https://nebula.wsimg.com/3a0733937917a1 ... oworigin=1
Schematics
Harness Diagrams
Be_Zero_Be
Be_Zero_Be
- Last Name: Strange
- Last Name: Hunter
- Board Member Since: 2002
A diode will indeed cut the power by half. But, an inductor reduces the power with increasing frequency (i.e. engine revs) which is why it is better suited to this application.
So, it functions as a choke.
- First Name: BOB
More like a variable resistance (actually reactance).
Be_Zero_Be
Be_Zero_Be
- First Name: Don
- Last Name: Demio
- * REQUIRED* Type and Year of Model Ts owned: 1919 T
Does anyone know of a commerccial source for the purchase of a Voltage Regulator/Dimmer Resistance Inducer that is compatable for a 1915 T?
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
The ‘15 Ts did not have a dimmer switch, and therefore no place for the dimming component discussed here. The magneto lights were just on or off, however, they are dimmer at idle and get brighter as the engine RPM increase.
Eric
Eric
