Throttle lever slipping
acereske
First Name: Al
Last Name: Cereske
* REQUIRED* Type and Year of Model Ts owned: ‘26 coupe
Post by acereske » Sat Aug 21, 2021 8:43 am
On my 1926 Ford Model T coupe the throttle lever slips down making an unwanted acceleration especially if I have hit a bump. The notches where the lever is supposed to click in are almost worn smooth. How do I fix it?
MWalker
Last Name: Walker
Re: Throttle lever slipping
Post by MWalker » Sat Aug 21, 2021 9:01 am
Bend the quadrant up so it's tighter against the lever. The real fix, of course, is to replace the quadrant with one which has notches. That's a lot of work.
Post by TXGOAT2 » Sat Aug 21, 2021 9:15 am
I believe one or more of the vendors sells a device consisting of two wooden blocks which clamp around the steering rod and lever rods below the firewall. The blocks can then be adjusted to give proper friction on the rods and prevent rattles.
JRSpada4
First Name: Jim
Last Name: Spadafore
* REQUIRED* Type and Year of Model Ts owned: 1925 Touring
Post by JRSpada4 » Sat Aug 21, 2021 9:20 am
In addition to bending the quadrant up like Mike said, the grooves in the quadrant are probably worn almost smooth. You can dress them with a triangular needle file. The springs on the other side of the column mounting plate are probably worn out too, but will require you to partially disassemble your column to do it. The temporary fix for that is the wooden clamp already mentioned.
Post by TXGOAT2 » Sat Aug 21, 2021 9:33 am
Glueing some kind of rubber material to the quadrant might help.
Post by Mark Gregush » Sat Aug 21, 2021 10:13 am
Another fix, which I have done, is to wrap a few turns of good stout cord tightly around the rods.
Post by Scott_Conger » Sat Aug 21, 2021 10:49 am
Post by TRDxB2 » Sat Aug 21, 2021 11:24 am
Pillory for you steering column. Whats old is new again :lol:
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat Aug 21, 2021 11:46 am
Your throttle lever may be bent and or worn where it contacts the quadrant, the quadrant may be bent or worn, the spring on the throttle rod may be broken or rusted or somehow damaged, or a combination of the above. What you describe is not normal, and the wood block recommended by some may be a good bandaid fix but is not the final solution.
Post by Steve Jelf » Sat Aug 21, 2021 2:04 pm
Titus told somebody on Facebook what year that Model T really was. :)
joe.wal
First Name: Joerg
Last Name: Walther
Board Member Since: 2014
Post by joe.wal » Sun Aug 22, 2021 7:23 am
I do have the same issue with a slipping lever since I thought I should oil the connection at the carburetor - now gravity is doing it's work on the system and I have to hold the lever up when I want to decelerate.
Is not the quadrant a cast iron so it might break when bending ?
I did not dare to put stress on it until now.
1916 Touring
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Sun Aug 22, 2021 9:58 am
The quadrants are drawn steel. There is a description of the manufacturing process in "The Ford Shops".
tiredfarmer
First Name: leonard
Last Name: simunek
* REQUIRED* Type and Year of Model Ts owned: 1926 touring. 1931 model a pickup, 1947 willys cj2a
Post by tiredfarmer » Sun Aug 22, 2021 5:48 pm
To bad that the steel quadrants are not being reproduced, I could use one on my 26 Touring.
Last Name: Hjortnaes
Post by DHort » Sun Aug 22, 2021 10:49 pm
Do not forget to throw some rotten tomatoes, apples, or cabbages after you fix the quadrant. Personally I would throw them away from the car.
Post by Original Smith » Mon Aug 23, 2021 11:26 pm
One thing I learned years ago, is to lift up on the spark and throttle levers when changing position. This saves wear on the quadrant.
Post by Rich Eagle » Thu Aug 26, 2021 1:06 pm
Thanks MWalker for the tip on bending the quadrant down. It worked great for me this morning. I had been putting off disassembly and adding heavier springs. This was much easier.
